Every 2 days I get a black screen when I turn on the computer
I would suspect a glitch in the MBR/software, a black screen with a white cursor in the top left, BUT, Try this , when you shut down always unplug, remove battery when you use at home connected to AC. At boot in BIOS, BOOT sequence, change to Boot from HDD first. Also remove DVD's, CD's from the DVD/CD rom drive, if the machine has boot from DVD/CD rom as a default, it will try to read the disk in the drive first, delaying a switch to second HDD boot. This is a general idea in the Boot sequence procedure: http://helpdeskgeek.com/how-to/change-boot-order-xp-vista/
SOURCE: Screen half black
ok it sounds like it is a wiring problem. what i want you to do is to take the dots on the side of the screen of. (not on the acual screen on the side of it there is plastic around the screen part so what i want youto do is on each cornor of the screen there is little dots i want you to take these off. youwill beable to put them back on just make sure u dont loose them ( i only have 1 left haaaaa) ok when youtake off the 6 dots 4 in each corner and 2 inbetween the locking mecanisim for the screen. after you do that the very top of the keyboard part not the aqual keyborad right above the keyborad is the plastic part that has the powerbutton and lights and the inspiron 6000 on it ok so you can take that off with a flat object.on the very right side there is a little indent on the wite part of the edge just pry it up. now you can see all of the wireing make sure everything is plugd in properly. if you need more help just email me a@ [email protected] that is also my msn messanger account if you would like to chat while trying to fix it.
SOURCE: my laptop screen is black
Try reseating the memory, if that doesn't work then take the battery out and only hook up the ac adaptor then turn on the laptop to see if you get video.
SOURCE: screen black computer laptop not starting
HP pavilion dv 9000 powers on , no display . but when i plug it up to an external screen it works. Can you help. mo
SOURCE: My laptop screen had an odd color to it a few days & is black now
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
SOURCE: Hi, I have a problem with my laptop(2 yrs old).
Sounds like a software error. When the screen has been blaxk for a minute or two try hitting control+alt+del and use the task manager to start the process explorer.exe if so then there is a registry or windows error and needs to be repaired.
