Question about Reddy Heater-170,000 BTU Kerosene Deluxe
SHOULD NOT BE SPRAYING FUEL OUT THE END. TURN THE PRESSURE DOWN BY TURNING THE FLAT HEAD ADJUSTMENT SCREW COUNTER CLOCKWISE IN SMALL INCRIMENTS.
Posted on Dec 25, 2012
SOURCE: Sears forced air kero heater wont start, spitting fuel out front
sounds like the ignitor is bad, mine would try to light and do the same thing. I noticed one night that it was arcing out the entire length of the wires to the plug. If you have a good spark then i would suggest a CAD flame sensor, very cheap.
Posted on Jan 22, 2009
SOURCE: ready heater 100,000 btu won't fire up!!!!!!!
go to www dot desatech dot com. you should be able to find what you're looking for here.
Posted on Jan 14, 2008
SOURCE: Reddy Heater 155,000 BTU
Question- "won't start" sounds like you have motor problems.
Posted on Dec 08, 2008
SOURCE: 70,000 BTU Ready Heater
If...the air pump pressure is right, the ignitor glows, the fuel is hitting the ignitor, then the unit will have combustion......unless.....
Posted on Feb 11, 2009
SOURCE: heater will not run
You don't say, but I am assuming that the motor is running and there is combustion in the combustion chamber and the heater is running fine, then the reset trips. Is this correct? If so, chances are the Safety Control (reset) is defective. Part number HA3003. The photocell could also be at fault. Check for a dirty lense on the photocell.
But---If there is no combustion in the chamber, then the photocell detects a no-flame condition and then it trips the reset.
Troubleshooting tips for a Spark Plug type heater
Posted on Nov 16, 2009
Jan 05, 2011 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Oct 21, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Sep 12, 2009 | Reddy Portable Forced Air Propane Heater...
Jun 13, 2009 | Hayward 100,000 Btu Heater For Ag Pool And...
Feb 25, 2009 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Jan 22, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Jan 06, 2009 | Dayton E50 Heater
Oct 15, 2008 | Heating & Cooling
Jan 13, 2008 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
65 people viewed this question
