Question about ASUS LCD Monitor
Asus DVI and HDMI connection not working on monitor
VW246H Asus DVI and HDMI connection not working on monitor but the VGA does.
Posted by Debbie Higgin on
wisiny.com
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 848 Answers
Asus DVI and HDMI connection not working on monitor? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
Posted on Jan 15, 2015
1 Related Answer
Anonymous
  • 23 Answers
SOURCE: input select button to switch between hdmi/dvi/vga
Unless there is simply some dirt or dust caught in it, I would imagine that the button has lost its 'spring' or bounce-back ability which means that either you can take the big risk of attempting to fix it or come up with some other clever way to give it bounce.
Posted on Jul 03, 2009
Why is my screen green?
you may change the connection cable
Aug 18, 2015 | ASUS VW246H 24 Widescreen LCD Monitor,...
VGA To HDMI ?
Here you go. Some very inexpensive and they work well.
https://www.amazon.ca/s/ref=nb_sb_ss_i_2_11?url=search-alias%3Delectronics&field-keywords=vga+to+hdmi+adapter&sprefix=vga+to+hdmi%2Celectronics%2C145&crid=1HJZTZOV9K2UA
Oct 08, 2017 | Acer AL1912 19" LCD Monitor
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
Help Adding a 2nd Monitor to ALL-IN-ONE
Try using a VGA to VGA cable or a dvi to dvi cable because dvi-d and hdmi tend to lack the necessary pins to be converted to an analogue signal. A hdmi to dvi cable may also work
Jun 12, 2013 | Gateway One ZX4970G-UW308 All-In-One...
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
Asus VW246H monitor has backlight problem. I hooked VGA up to laptop and the monitor turns on but then 2 seconds later it goes very dim. how do i change the backlight settings?
how do i change the backlight settings? This trouble maybe power supply or inverter boards is defective.
5E 0NC02 001 4H 0NC02 A01 ASUS 5E 0NC02 001 Power Supply Backlight...
Mar 29, 2011 | ASUS VW246H 24 Widescreen LCD Monitor,...
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DFid something, In my CPU i dont have the slot for the other type DFi, ...
I believe you are referring to a DVi connector. We have different types of connectors but none of them is DFi. We have VGA, HDMI, SATA, and DVi connectors. Here's a cheklist of what you need to do:
  1. Check the connector of the computer whether you have VGA, HDMI, SATA, or DVi
  2. Check the connector of the monitor whether you have VGA, HDMI, SATA, or DVi
  3. Now that you know the type of connectors you have for your system, you know what cable to buy.
It does not really matter if your computer and monitor have different connectors. We can purchase cables with VGA - VGA, HDMI - HDMI, DVi - DVi, VGA - HDMI, VGA - DVi, HDMI - DVi. So, don't worry and thank you for choosing FixYa!
Feb 21, 2011 | Acer X193W LCD Monitor
What kind of connector do I use to connect a dell laptop to a Hitachi 42'' plasma display? HDMI to DVI or HDMI to VGA?
If the TV has a VGA connector then use a VGA to VGA cable from your laptop as most laptops have a VGA output. Otherwise use one of the other combinations that work HDMI to DVI or HDMI to HDMI..
Nov 11, 2009 | Televison & Video
Input select button to switch between hdmi/dvi/vga is stuck. cant use any other buttons on the monitor except power. if pushed it continues to cycle thru the three until i pull the button out a little....
Jul 03, 2009 | ASUS LCD Monitor
ASUS LCD Monitor Logo
251 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
