Brainydeal Agptek 7" 1.2 Ghz Tablet Pc 4gb Google Android 4.0 Tft Capacitive Touch Screen, 800*480 1080p And 5-8 Hours Battery Life Black Logo
Junelle Posted on Dec 25, 2012
AgpTek android 4g tablet charger doesn't charge my tablet !
Is there a universal tablet charger?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
607
Points
This solution worked for about a couple of months, but now I'm looking for a replacement power supply also. I wiggled the tiny adapter plug while it was inserted in the tablet and found that it would make contact at a certain angle and pressure. So I got a long fat rubberband and used it to make proper contact by rigging it diagonally, across the tablet. Be careful as too much lateral pressure will bend the plastic sleeve of the contact and render it useless. My theory is that the original problem was partially caused by using the tablet while charging and thus damaging the plug. Although this is a persistent complaint / problem with AGPteK tablets. Mine didn't even last 6 months.
  • Anonymous Feb 19, 2013
  • Bestway Aug 16, 2014
    It is a hardware issue. There is a slight connection problem in that the connectio may need to be re-soldered.
My Kocaso M9100 will not charge up
Are you using the original charger cord? You can also charge your tablet with a universal cord originally used on Android phones but it is now usable on all phones...great improvement!! Take your tablet to Best Buy or your cellular provider to have them test to see if the universal cord will work...if so, you can order it on Amazon a lot cheaper!!
2answers
Battery will not charge
it means that something is wrong with your battery or its charger
My coby MID7012 isn't going to the home screen after I charged it. Its flashing coby over and over. But its not turning on. What do I do?
Sounds like you are in a "Boot Loop". Let's try to break the Boot Loop. Plug the device into the charger, then press and hold the power button for 60 seconds - make sure the device is OFF after the 60 seconds. Let change overnight. Next Day, unplug the device from the charger, then press and hold the power button for 30 seconds, wait 30 seconds, press and release the power button normally, the device should be out of the Bootloop.
Coby Kryos Android Tablet is not charging. It is connected to a charger but its not charging.
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Htc amaze 4g wont turn on after charged
Try leaving the battery in with it charging all night, if the phone won't turn on after that, you'll need to exchange it.
My agptek 7 inch charger doesnt work unless i push the charger in
Carefully check to see if there is something stuck in the receiving hole for the charger. It might be just a piece of paper or lint. Pull it out carefully!
2helpful
Replacement parts for 7" AGPtek Android tablet
I believe the person asked where to get replacement parts for tablet PCs, not for commentary on the price of parts or their skill on electronics repair.
Best place I have found to get replacement parts for microelectronic devices is ebay and amazon, although with an off brand like AGPtek you may be forced to purchase the parts through the manufacturer (most likely for a SIGNIFICANT markup.) I know with my AGPtek TP15 tablet, replacing the glass digitizer consists of disconnecting a couple ribbon cables and attaching the replacement. Getting the parts is the hard part.
Top Brainydeal Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Brainydeal Tablet and eReader Expert? Answer questions, earn points and help others
