SOURCE: Epson LQ-590 Matrix Printer Paper feed Problem
Assuming that you are feeding the paper into the correct end of the printer :), it seems that the printer is defective, but
First unplug the printer from the wall, wait a few minutes,
and see if it resets. If that does not work, read on.
Also do not forget that printers are dirt cheap, less than the ink when it runs out, so this may not be worth your time and effort.
are controlled by "Stepping Motors"
Unlike an ordinary DC motor with two wires, that spins
clockwise or counter clockwise depending on the voltage
polarity,
a stepping motor contains several pairs of wires, that
are pulsed in a controlled sequence, causing the motor
to spin in precise angular steps. Depending on the
number of wire pairs (poles) and internal gears, the
stepping motor can have a resolution as course as
90 degrees, and as fine as 0.05 degrees per step,
depending on the cost and applications.
Linear stepping motors can even move an object in
a straight line.
The benefit of these stepping motors is that, unlike a
linear servo motor, they do not need complex positional
feed-back for precise control, they simply step as many
times as you tell them to. Four steps left, two steps back
.... etc.
ultimately controlled by a central processor within the printer.
Depending on the printer model, and how sophisticated
the printer's internal processor is, the paper and head
movements can be either automatically controlled by
SOFTWARE (firmware) within the printer itself, or by the device drivers installed in Windows.
The more self-sufficient the printer is, of course, the less
hassle and CPU overhead on your PC.
a) Skip steps
b) Get stuck
c) Oscillate back and forth
d) Spin backwards.
a) One bad wire in the ribbon connecting the motor
to its controller board.
b) Bad motor driver transistor: Open or shorted.
c) Bad data line from the printer's internal control
processor to the driver transistor array.
d) Bad processor chip, memory or firmware within
the printer, e.g. a burned out register or firmware
memory location.
e) Defective internal power supply, causing everything
else to malfunction.
f) Bad paper position sensor
d) Crashed control program, which is probably the
only thing that is fixable:
i) unplug the printer from the wall socket, wait a
few minutes, and see if it resets.
the Window drivers are corrupt but this is very unlikely.
Is one of the motor windings open or shorted ?
Is one of the driver transistors fried ?
This very much depends on your level of skill, and the test equipment you have to work with. If you don't have a decent oscilloscope you will not get far. Without a digital multimeter you will not get anywhere at all.
Call the manufacturer, scream blue murder, accuse them of setting your house on fire and giving your dog diarrhea ....
and see if they will send you a freebee.
Hope this explains it.
Please rate my answers.
Martin
SOURCE: Broken paper feed roller
you cn the roller from the link below:
http://www.precisionroller.com/manufacturers/hp-photosmart-c5280.html
SOURCE: I have 2 Dell model 1700n laser printers and they
Take off the two rubber rollers, turn them inside out and replace them, Voila!
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
SOURCE: After paper jam was cleared my printer wont feed
There is a small plastic gear that turns the roller, and when a paper jam occurs, oftentimes the gear strips it's teeth, and then the roller won't turn and feed the paper. I had this happen with an HP printer, and took it apart to see what the problem was. Upon finding the stripped gear, I tried to contact HP to get a replacement part and was told that they don't sell parts to anyone except HP authorized dealers, so I found a used printer and cannibalized the part, replacing it myself. Unfortunately, the broken gear problem happens a lot. About the only thing you can do is maybe load less paper, or load just the sheets you need for your print job, but even this doesn't guarantee that a jam won't occur. If you use labels a lot, they can leave glue residue on the rollers, causing a jam. You just have to keep them clean and hope for the best. In my opinion, the clean roller maintenance doesn't always work, and just a small amount of adhesive on the roller(s) can mess you up. They use a lot of plastic parts in printers these days, so they're very susceptible to breaking. Unfortunate, but that's the way it is. I guess that's their way of ensuring the printers won't last an awful long time, making people buy replacement printers sooner than they should have to. Don't think any one printer is necessarily better than the other, these days, so just try not to overload the paper and hope for the best. Sorry I don't have better news, and good luck.
