Plumbing Logo
Question about Plumbing
Replace diverter in 2 handle aqua source kitchen faucet
Access diverter valve
Sooner Crazy
    New Friend:
For a dual-handle Aquasource kitchen faucet with spray hose, the following instructions will afford replacement of the diverter. These instructions specifically refer to the faucet illustrated at http://pdf.lowes.com/installationguides/6953123900358_install.pdf, and the diverter identified as part RP70007 (item 14). Note the position of notches at the top of the diverter and around the rim of the base of the diverter, either of which can be used to leverage a tool to rotate the diverter out of position. Caution: The diverters on older faucets may be exceptionally brittle and thus very difficult to remove.
1. Using a pipe wrench or similar large-mouth wrench, unscrew the base of the faucet. Wrap the base with a cloth or other protective material to prevent scratching during the process of unscrewing. The base unscrews in a counter-clockwise direction.
2. With the base removed, remove the faucet. Note that a small amount of water may drain from the faucet when removed.
3. Removal of the base reveals the top of the diverter, which is a white, plastic cylinder approximately two inches long with copper stopper in the bottom. Insert a wide, flat-blade screwdriver across the notches in the top of the diverter - but be *extremely* careful. A faucet that has been installed for some length of time may have an exceptionally brittle diverter. If the upper shaft of the diverter breaks, a pair of needle-nose pliers may be used in the notches around the *base* of the diverter. Carefully rotate the diverter counter-clockwise to remove it.
4. Insert the new diverter and screw it into place in a clockwise direction. Apply a wide, flat blade across the notches in the top of the diverter to apply slight additional pressure to tighten the diverter just beyond hand-tightness.
5. Re-insert the faucet.
6. Screw the base back into position, tightening as necessary.
7. Test the operation of the diverter by operating the cold and/or hot water faucets, then the spray handle.
Posted on Dec 29, 2016
3 Related Answers
Anonymous
  • 119 Answers
SOURCE: Trying to fix leak on kohler fairfax kitchen
You need to remove handle and cartridge and spout should come off to replace the rest very common leak
Posted on Nov 15, 2009
pl2323
  • 89 Answers
SOURCE: I have a Grohe Ladylux plus kitchen faucet very
When you remove the screw, you will have to give the handle a slight pull to take it out. Sometimes it is stuck after being used too long.
Posted on Aug 10, 2010
Thomas F. Schneider
  • 2715 Answers
SOURCE: How to remove the corroded valve seat housing in my tub faucet
Some seats ae rremovable and some or not Some take a hex(allen) wrench and some take a square (seat removal tool)  Most of us use a seat grinder. (another tool to dress up the seat (Remove material) past the seat damage. You will find any of these tools at any hardware store that sells plumbing parts. If the seats have a square or hex hole remove and replace rather that grind(dress)the seat. All right hand threads meaning turn counter clock wise to remove. Take old seat to the American Standard plmbing supply outlet and then will match it up. Good fix-in to ya.
Posted on Feb 08, 2009
1helpful
We need to replace the 4 way valve for our bath tub/shower faucets. Parts from the schematic "101 - CENTRALE 4 VIE C/PROLUNGA CM.4" (Rubinetteria "SIMBOLO" Aqua Brass faucets
take the details along to a plumber supply shop ( not a hardware shop or mart) and there will be some one there that will be able to advise on parts , problems or replacement equipment
No water comes out
If it's a kitchen or lav faucet, unscrew the aerator and clean or replace it. A kitchen faucet could have the diverter jammed with debris. Look on line to see how to remove the handle and spout to clean it. If it's a shower valve, just replace cartridge.
Spray and single flow both running at same time on Moen single-handle kitchen faucet. How do I correct the problem ?
there is a diverter inside the faucet that works with water pressure possibly has some debris or calcium build up.turn off water supply and take out cartridge. you should see the diverter
2helpful
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Re Delta faucet 172-WHWF The spray assembly has a long delay in getting water to it. Would a new diverter valve fix that problem? If so, what is the part number for the diverter valve for this...
Before you start replacing parts look under the sink and make sure the hose leading to the remote spray is not kinked or starting to kink when pulled out.
10helpful
2answers
Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
3helpful
2answers
When the water is turned on, the faucet "sputters" and "hammers" as if the water had been turned off then back on when it hasn't been. Plumber says we need new part (inside cartridge 070807-Aqua Source)....
The USUAL cause of this is the diverter valve that channels the water to the sprayer. There are several types of these so search for yours in google to find a blow-up drawing of it. They are usually in the tower the spout swings on and sometimes are a pintle valve like a little rod with dumbells on the ends. Crud can make them not seat then they will cause the hammering.
Moen kitchen faucet leak from spray
This might mean that the diverter in that controls the sprayer needs replacing. It is located behind the valve body underneath the tub spout sleeving
1helpful
Greetings! My Kohler kitchen faucet model K-10416 with sprayer (16 months in use) is making noise when water is turned on in both hot and cold positions. Also, when sprayer is used water flow is not being...
Begin by shutting off the water to the faucet. Then, on the back of the handle you will find a small button. remove it with a small knife blade and underneath you will see a 1/8" set screw. Use a 1/8" inch allen wrench to remove the set screw. You can then unscrew the bonnet and remove the diverter. Take the diverter to a hardware store or plumbing supply to purchase the appropriate repair kit. goodluck.
Jan 20, 2009 • Plumbing
Top Plumbing Experts
john h
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
