I need to find and replace all 4 knobs
SOURCE: Maytag MEC5430 cooktop burner indicator lights not working
If indicator lights are all that wont work there is a "P" terminal on the surface switches (unless they are controled through a board). The P is for Pilot And 1 side usually the "P" terminal of the switch is allowing the light to recieve the power signal that the element is recieving from the switch. The other side of the pilot light(s) will all be wired together at a "common" pont.
My guess is that if you have individual piolet lights this common point is not tied in to the circut now. 1 wire off or loose and none of the lights work. However it should be simple to trace back to this point and effect repair to it.
SOURCE: Hello I am looking for
V&V Appliance Parts - Strong in Service - Established 1959 Click on this link and V & V web site should be of help.
Yes is a part no 1
COOKTOP
Part Number: AP4360879 made by WHIRLPOOL
$199.78
in the follow link you can find all parts of your model
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170740&diagram_id=1333343#d1333343
