My ford G6E Turbo 2010, gear shift indicator light won't switch off! I have removed key locked doors and tried everything I can think of and it is driving me insane! Any suggestions? Thanks.
Look in the owners man. to see if it has a progrramable function setting.this feeture will tell you how or what to do to turn it off.you may have to turn the key on and off a certain amount of time or something of that sort.i've had to fine this info. for the passenger seatbelt buzzer in my F-350.yes it is a pain in the a#$.lol
SOURCE: 1995 crown vic gear problems/gear shift wont lock
most likely the shift tube bushings are bad- you may have also lost a few screws in the shift tube or they could just be loose. you have to pull the steernig column down to inspect/repair it.
SOURCE: None of the power door lock switches work.
Have you checked the wires between the doors and body, they will break in time, and yours is a year where they could be broken now, they don't last forever.. that will cause the fuse blowing, and the locks not working.
Check all doors, but most likely the Drivers door or Passenger door will be the culprit......
Do the brake light work? No brake lights and it won't shift out of park. Check your fuses and check for loose wires. Check your brake light switch. If that has failed, you won't be able to get out of park. The other one if the shift lock solenoid which is in the shifter assembly. The brake shift interlock switch prevents the car being shifted from park unless the brake pedal is depressed. Try to apply power/ground to the proper wires & see if it will activate.. If it does, then the problem is between the brake light switch & that solenoid. Could be the wires or the switch.Make sure the shifter cable is still held down in place at the shifter assembly & under the hood. It is the interlock switch that you hear/feel clicking.It is for the prior generation but may still apply.
Good Luck and hopefully you soon will be on the road again...;-)
Thanks Stephen. I have read the manual in detail and I can't see any reference to the lighting on the gear shift indicator panel that may explain this issue. Interestingly it went out after about 30-45 minutes. Very, very strange???
GO FIG. thats ford thinking!!!yes
Dads FG 50th anniversary “P” lights stays illuminated too.
