Question about Compaq ProLiant DL380 Server
HP DL160 g6 need to activate boot from DVD
I want to boot from Solaris DVD, however in BIOS it showing that boot from DVD is disable, can ay one suggest how to activate Boot from DVD from BIOS then change the boot order. Many Thanks
Posted by fyamine on
murbak359
    Filmmaker:
    Uploaded 5 video answers.
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 45 Answers
Hi Fyamine,
While booting go into the BIOS, use either the dedicated keys or +/- to enable/disable the CD ROM boot ( in the Advanced section of device management), then go into the advanced boot tab and change the boot order (it should be CD->HDD->Pxe->Disabled by Default). After that, restart the server and wait for it to boot from the disk.
Posted on Dec 24, 2012
What is the fault when the battery light flashes orange (suspect dead batt), also the unit will not boot, nothing from the screen, and the blue power and Wifi lights are illuminated?
1. Suspect dead battery- Your battery might be dead. just replace your battery.
2. Cd-drive spin but cannot run
- solutions is -
1. Please check if the support DVD has been damaged
2. Please check if the external optical DVD drive can work normally
3. Please unplug other USB devices
4. Please disable [Boot Booster] in BIOS
4.1 Start the system and press on bootup to show the POST screen. Press again to enter the BIOS setup.
4.2 Set Boot Booster to [Disabled]
4.3 Press to save the configuration and restart Eee PC.
Alos with other solutions,
ASUSTeK Computer Inc Support Troubleshooting EEE PC 1000HE
Jan 19, 2014 | ASUS Eee PC 1000HE Netbook
I forget bios password for HP DL160 G6 server, how do i reset the password ?
  1. Shutdown your server.
  2. Go inside the server, and remove the CMOS battery. It should look like this.
3. Be sure to power down your server before taking it out. Be aware that once you take this out the system will forget a lot of it's time settings. This is the battery that keeps the computer's memory of time, date, and BIOS password when it's shutdown.
Apr 14, 2013 | HEWLETT-PACKARD HP ProLiant DL160 G6...
How to boot from CD hp proliant ML 110 G6 sever
Check BIOS for boot sequence. CD-ROM / DVD should be 1st.
Jul 20, 2012 | HP ProLiant ML110 Server
How do I boot from an external CD? The BIOS offers no boot options other than the hard drive. I have attached a USB connected CD drive but the computer will not boot from it. The machine will also not...
The HP Mini are kind of odd, the external CD/DVD or usb drive will only show in BIOS after you plug it in, power it on and then reboot. Then go into BIOS and it should list it in boot priority list. Move it to the top and reboot and it will boot from CD. Also you can press F9 instead and it will let you select the boot device.
Comment back if you need any more help.
Aug 30, 2011 | HP Mini 1000 Netbook
Hi, I want to replace windows with Solaris. Im unable to change the boot sequence. Please give me the detailed explanation.
If you enter the BIOS menu just before the system boots up, you can choose whether to boot from DVD ROM, LAN, USB etc. Just select what you require and save it.
Dec 19, 2010 | HP Compaq nc6000 Notebook
ProLiant DL160 G6 Server, Part Number 593352-B21, Serial Number USE029N5Z2. The system fails to power on. The power supply has the LED light green. The start button does not turn amber. Do not...
ProLiant ML150 G6 and DL160 G6 (HP Smart Array B110i SATA RAID) does not support more than 4GB memory, (2GBX2 modules) or more added, it works fine with single 2GB module. Boot OS with single module and upgrade system Rompack to the latest version then upgrade B110i controller driver to 6.8.0.32. Shut down the server, add additional modules. It will work fine.
Aug 04, 2010 | HP ProLiant DL160 G6 Server - 1 x Xeon...
How do I install sun solaris from a grub prompt when I boot off the setup cd
A grub prompt is most likely coming off the hard disk where you're attempting to boot.
Restart the machine and adjust the bios settings so that the PC will attempt to boot from the CD or DVD drive before attempting to use the hard disk.
It's possible that you may need to burn a new image of the sun solaris ISO. That may be where you need to get help, if your system doesn't seem to be able to boot from this CD but CAN boot from others.
Jan 23, 2010 | Sun Solaris 10 3/05 (SOLZ910AC9A7M)
Compaq ProLiant DL380 Server Logo
1,608 people viewed this question
Top Compaq Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
