Question about Dell PowerEdge 1600SC Server
Pcie training error slot2 - Dell PowerEdge 1600SC Server
1 Related Answer
Rishi Roshan Ali
  • 2427 Answers
SOURCE: If we use the server
The problem seems to be 2 things..
1.) firstly send the boot priority in the bios to HDD 0 or the harddrive connected directly to the board with the os.
2.) second thing, the Raiser Card, if it has raid Harddrrives connected via the ext. one of the raid harddrives connected to it is malfunctioning , remove and disable one at a time until u find the correct one. Or it could be the Card itself is malfunctioning.
I'm guessing here that you have a IDE card connected to the Raiser card with raid harddrives on it, One of them is malfunctioning.
Posted on Apr 01, 2011
In my acer aspire 7721 I would like to install a new soundcard! some say this is not possible! is someone know this for sure? if i can or not? it would be an soundblaster audigy???
Yes you can. A Soundblaster Audigy FX would work. Be careful to get a PCIe card, and not the older style PCI card. Your PC ships with several free PCIe slots.
2 (total) / 1 (free) x PCIe 2.0 x16
1 (total) / 1 (free) x PCIe x4
1 (total) / 1 (free) x PCIe 2.0 x1
You should install the sound card in the PCIe 2.0 x1 slot if possible. If not any of the others should work as well.
Oct 19, 2017 | Acer Computers & Internet
I have problem in server dell poweredge 1900 it is orange light and wright error E171F PCIE fatal D4 F0 B0
Hi
Don't have a Dell, but the link below appears to give a solution that some people have found works for them
http://pcrepairpro10.com/dell-e171f-pcie-fatal-err-b0-d4-f0.php
May be worth trying.
Good luck
Jun 25, 2014 | Dell PowerEdge 1800 Server
Error in play crysis 2 unsupported videos card
It looks like your card is below the minimum requirements for this game. You will need a faster (newer) card to run this game. It's not surprising, as many of these shooters have very high system requirements, and your 3-4 year old card probably wouldn't cut it even if it did work.
The good news is that a new card will run it faster and look better. Since your old card is PCIE 2.0 compatible, make sure that your new one is also 2.0 compatible. (Unless you know for sure that the mainboard supports PCIE 2.1) PCIE 2.0 cards will work on 2.1 mainboards, but the opposite is not true.
Here is the link to Crysis 2's minimum specs:
http://www.ea.com/crysis-2/blog/pc-specs
Dec 28, 2011 | MSI N8400GSD1GD3HLP GeForce 8400 GS (1 GB)...
I can't use both sims at one time. when simcards are in slot1 & slot2 i can see only "sim1 - operator name sim2- empty" but every simcard is works good single in slot1 or slot2. But again i...
you will need to configure the cell to select both 1&2........on your cell (settings) choose both sims and you should be able to rename both sim cards
and even then only one sim will work at a time (yes you will get text and/or message on the other sim while using the other)
Apr 10, 2011 | Cell Phones
If we use the server without PCI-PCIe Raiser card, it can boot into the OS. However, it cannot boot into the OS when we install the PCI-PCIE Raiser Card into the sever, and it alerts message error as...
Apr 01, 2011 | Dell PCI-X Riser Card for PowerEdge R200/...
I have the Board ASUS P5VDC-MX. And I wonder that there is no pci-e slot, but in the information there is written:"this board is pci-e (16x) ready".... is it right ? Can i use a pci-e (16x) video...
No, you can't use a PCIe x16 card in any of the slots on the P5VDC-MX board. A PCIe x16 card can't fit into the PCIe x1 slot. Attempting to force a PCIe x16 card into the PCIe X1 slot will break the card or bend the pins. A PCIe x1 card will work in a PCIe x4, x8 or x16 slot, though. Similarly, the AGP and PCI slots are not compatible with the PCIe x16 card design.
I wish that I had better news for you.
Aug 19, 2017 | ASUS P5VDC-MX (P5VDCMXGREEN) Motherboard
For Atheros PCIE Ethernet Controller... check cable connection PXE-E63:error while initializing the NIC PXE-MOF:exiting intel PXE ROM No bootable device-insert boot disk and press eny key happened after...
You didn't list your PC model or make, but it appears that you have enabled the network card to boot from it's rom chip. Turn that option off in your software or pcie Bios control.
Mar 15, 2010 | Computers & Internet
Dell Optiplex GX620 not recognizing PCIe video cards
One of two things could be doing this:
1: Bad Video Cards
2: Bad PCIe slot(s)
If avaliable, I would test the video cards on a PC with a PCIe slot to verirfy if the cards are good/bad. If they work, your PCIe slot is bad and need to have the motherboard replace to correct.
Good Luck
C2Solutions
Aug 27, 2009 | Dell OptiPlex GX260 PC Desktop
Dell PowerEdge 1600SC Server Logo
1,411 people viewed this question
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
