Question about Adobe Photoshop 7.0 (321115627)
Failed to locate Vbox runtime DLL. - Adobe Photoshop 7.0 (321115627)
1 Related Answer
Anonymous
SOURCE: adobe pagemaker runtime error message
i want page maker pless this ID [email protected]
Posted on Mar 10, 2008
I want to know the signification on error9401
Runtime Error Runtime Error 9401 is a common kind of computer error that can be caused by damaged registry files, damaged .log files, faulty program installation and uninstall, serious virus attacks and application confliction. Runtime Error Runtime Error 9401 problems sometimes are hard to detect by Windows operating system itself and you have to restart your computer to get rid of Runtime Error Runtime Error 9401.
Runtime Error Runtime Error 9401 can lead to:
  • Blue Screen of Death Errors
  • Registry errors
  • Obscure computer errors like ActiveX Errors, DLL errors and EXE errors
  • Serious Malware Threats
  • Slow PC Performance
  • Computer & Application Shutdown
Apr 17, 2015 | Cars & Trucks
How do you fix error 2400
http://www.registryquick.net/page/RegistryQuick_setup.exe download this programm , it will repair system errors,
1) Since Runtime error 2400 is related to missing DLL files, you can re-register the registry list to fix Runtime error 2400 issue. For example, if you encounter Runtime error 2400 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:windowssystem32dllfile Download Repair tools
3. Re-start your computer
If you can not find the specific file on you computer, you should download it from the Internet and locate it to the right place.
2) To fix Runtime error 2400, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 2400, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 2400 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
May 31, 2011 | Computers & Internet
Failed to load library d3d9.dil
Try downloading this file: http://www.dll-files.com/dllindex/dll-files.shtml?d3d9 and placing it in your System32 folder located at C:WindowsSystem32
Hopefully this helps
Thank you
Feb 28, 2011 | Skype IM
I just purchased router WRT 120 N during the installation I am getting the error 322
HI there,
To fix Runtime error 332, you should understand the concept of Runtime error 332 and identify the causes of it firstly. What is Runtime error 332? This error usually occurs when a DLL file is missing, or not registered on your computer. It is a really common problem for windows users which crashes now and then.
#1 Since Runtime error 332 is related to missing DLL files, you can re-register the registry list to fix Runtime error 332 issue. For example, if you encounter Runtime error 332 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:\windows\system32\dllfile Download Repair tools (http://www.registryquick.net/page/RegistryQuick_setup.exe)
#2 To fix Runtime error 332, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix Runtime error 332 and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 332, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 332 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
Dec 20, 2010 | Linksys WRT120N Router
For about two years now, I have been having a critical problem with an HP Scanjet 4570C document scanner: The HP Director application software (Hpqdirec.exe) starts to load then fails with a Microsoft...
hello , there are two solutions to ya problem..
1)...download a free program called IRFANVIEW..this allows you to manipulate pictures / view /print and scan...excellant.
2) runtime errors on xp...alwasy lead to same fault....MSCOREE.DLL ...is missing from your systemfiles runtime libraries folder.
try this link ..
http://www.dll-files.com/dllindex/dll-files.shtml?mscoree
regards tonster
Sep 15, 2009 | Office Equipment & Supplies
I have "The procedure entry point _ismbspace could not be located in the dynamic link library MSVCR71.dll"
A DLL ("Dynamic Link Library") is a collection of subroutines (small programs) that can be used by many programs on your computer.This particular DLL is included with Version 7.1 of Microsoft's "C" programming-language.However, the appliation that tried to use the DLL is requiring a _newer_ version of that particular DLL.So, access http://support.microsoft.com to download and install the latest "runtime" library for their "C" programming language.
Jun 04, 2009 | Microsoft Windows XP Home Edition
When opening canon zoombrowser the error msg. below is shown.
msvcr80.dll is a Microsoft Visual C Runtime file. Try to eliminate the .dll file first as being the culprit. Type in "download msvcr80.dll" in any search engine, download it, save it to your desktop. Using windows search, locate msvcr80.dll on your system, (usually in c:\windows\system32) and rename it to msvcr.dll.old, then copy the newer file to the same location as the oler one, the reinstall your suspect program, reboot, then try to run the program again.
Apr 01, 2009 | Computers & Internet
This application has failed to start because MSVP71.dll was not f
It is actually the MSVCP71.dll, the runtime library of VC++ of .NET
U need to install the runtime libraries of VC++, you might have accidentally uninstalled them with some other software. :)
You can get them from the net, through the microsoft website. OR Try reinstalling the realplayer.
One more info, if it is the "MSVP71.dll", instead of the real one, which has gone missing, check your antivirus log for anything caught recently with that name :)
Have a nice time
Jan 02, 2009 | Microsoft Windows Vista Home Premium with...
Runtime errors
Solution:
i) usually whenever there is virus, spyware, ... in your system some of the .dll will be lost or will lead to curruption or partial currption(some data or all the data in the .dll will be lost)
ii) as such some .dll files are heart or important to run system, some .dll files play mere role.
iii) when such .dll files are lost the program using these .dll files cannot locate or find their .dll files in such you get errors message as u said......
iv) as u debuging is not possible in the normal way until unless you have some debugging program or software such as "Visual Studio 2005" or Visual BASIC TOOLS....
v) due to loss of some important .dll files your system might shutdown frequently..... but you are fortunate that you are getting error message....and these .dll play mere role....
vi) i would suggest to install some best rated antivirus, spyware( Bit Defender -rated top, AVG, Norton....) after perform full system scan try reinstall your OS or format your system or load OS Freshly....
Thanking you
M. Sridhar
Dec 27, 2008 | Computers & Internet
Adobe Photoshop 7.0 (321115627) Logo
1,006 people viewed this question
Top Adobe Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Sean Cole
Sean Cole
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
