No sound in any configuration. I've always hooked up my receivers from the tv optical out to the receiver optical in. The only optical that lights up on the receiver is the optical out. I haven't been able to get any of other optical ins on the receiver to work. The optical out on the tv is lit up and the other end of the cable is also lit up. I have also selected it on tuner and tried an antenna and got no sound. I've even turned it up all the way and not any hiss out of the speakers.
SOURCE: Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
SOURCE: Statics and hissing...
I also have the same fault, The static noise is coming out
of ic720 [ cs4391 or cs4392 ]on digi pcb which is D-A converter
this ic maybe faulty, i have ordered a replacement ic and will
post here if solves problem
SOURCE: I have the following hardware:
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
