Question about Scubapro Mk25 & A700 High End Regulator By Authorized Dealer, Scuba Diving,
I have been using my A700/mk25 for six month and recently it has been making a whislting noise when I inhale.
Six months old, does about 15 dives a week and gets cleaned after every use.
Posted by lic_sip_suck on
Dan Jacobs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 808 Answers
The whistle noise is some thing loose (torn o-ring) inside the second stage. this is covered under warranty. scuba pro offers a parts for life program which is no cost to you if 1st & 2nd stage with a computer are bought at one time. just pay service labor. the whistle noise will be repaired are replaced free under 1 year.
Posted on May 16, 2014
Ryobi drill seized
Take it back to the supplier as it will be under warranty
Aug 15, 2017 | Ryobi Drills
My beko washer is only six months old its washed all day. On last load it has started to make a loud metalic noise while emptying and spin its like something is stuck but filter empty
Is it out of warranty?? It sounds like the washer drum bearing failed. Do you use approved super low suds detergent? You can not use regular detergent it will corrode the drum bearing.
Jun 01, 2016 | Beko Washing Machines
Hi I've had my HP laptop from Telus for approx six
Dead battery? If it's six months old return it A.S.A.P.
Jan 18, 2013 | Computers & Internet
The dryer is only about six months old and is making a weird screechy sound from the back and not drying anything
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 17, 2011 | Haier Dryers
Six year old Whilpool Duet washer on pedestal and level front and back still vibrates excessively and makes loud noise when spinning water out of machine. Is sitting on concrete floor. Have owned since new...
check the inner struts on the bottom of the tub you need to remove the front panel some have a split lower section so you can access inside where the struts are also check that the struts are not worn out hope this helps
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The machine (ir2018)is six months old, The password was tempered
under service mode: * 2 8 *, under clear, select all and OK. then set up copiers properties and settings again.It should be OK.
Apr 23, 2010 | Canon iR 2016i Black and White Copier
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Our monitor (less than six month old) won't power up.
This is 2005 model, 3 year warranty. 6 months old?
http://www.amazon.co.uk/LG-Electronics-L1915S-LCD-Monitor/dp/B00076V8TY
You will need to open it up, first thing to look will capacitors int ehpower supply, main AC fuse.
http://s807.photobucket.com/home/budm/allalbums
Please verify if it is only six month old, otherwise, take it back to where you get it from.
Apr 06, 2010 | LG L1915S 19" LCD Monitor
1997 chevy blazer s10 cranks but wont start
You have a new battery and it cranks. Turning over is cranking. You are saying it won't start after sitting for six months? What is an old mechanic? Was the cable installed at home during the one year layoff? It sounds as though you failed to hold the old mechanic responsible for installing the correct cable or adjusting the one you have ,so it will start. You have a safety switch issue by the sound of it. Make sure you have the right cable and then find out how to install and if applicable,adjust properly
Feb 07, 2010 | 1997 Chevrolet Blazer
Scubapro Mk25 & A700 High End Regulator By Authorized Dealer, Scuba Diving, Logo
343 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
