Question about Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv
Only runs with choke
Always ran perfect, then this year started and only runs with the choke position and when I move the choke lever to run it stops running. It has to be on choke to run.
Posted by Alan on
Leigh Perlmutter
    Genius:
  • 1,669 Answers
There is an air leak in the seals somewhere between the carb and the intake manifold. You are getting too much air! ALL of those seals need to be changed, As the paper seals age they develop small cracks that kill the vacuum made by the engine to pull in the gas/air mixture!
Posted on Dec 26, 2012
Just starting to use this spring, and having fuel starvation issues. I ran it this winter a couple times and it ran properly.
add a little carb cleaner to the gas and try letting it run on half choke for a while longer .
Mar 28, 2015 | Garden
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
How come weedwacker tries to crank while on choke but when you move lever to 2nd position it tries to crank? but wont
When mine does that I go back and reprime repeating the process. It seems the gas does not feed up fully with the initial priming effort. Once it starts I move the choke lever quickly on way or the other to see if I can keep it running until it gets warmed up. Sometimes I have to adjust the choke setting even after it has run for a while.
Sep 21, 2014 | Craftsman WeedWacker Gas Trimmer 25cc...
Adjusting the automatic choke on my Honda GCV 160
you move it in very small moves and be sure to mark the starting place
Jan 25, 2018 | Garden
2300 psi power washer stopped,
the spark plug could have got fowled out from running rich
Aug 11, 2012 | Briggs & Stratton Garden
Starting procedure for stihl 012 av
Full choke, stop switch on run. Pull rope handle 3-4 times or more until it "tries to start" (it will not start, but it will try to for a split second) move the choke lever to the half-choke position and without pulling the throttle, poll the rope handle until the engine fires and runs for 4-5 seconds then fully open the choke to the run position, let it warm up for 25-30 seconds (don't forget to let it cool down about 45-60 seconds before you turn it off!) and then proceed to use it.
Aug 07, 2012 | Stihl Garden
Honda mini tiller cuts off when start tilling. runs great when held above ground with no load. cut off seems to be associated with the movement and shacking when tilling ground.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Dec 10, 2010 | Honda 25cc 4-cycle Mini Tiller
I left the bike in my garage and now it wont start, what could i do?
hi friend,
Move switch to ON position
Locate your dirt bikes OFF/ON, RUN/OFF, or START Switch. Use your finger to move the switch to the RUN, ON, or START position.
  • Step 212233_65x95_aspect.jpg Turn fuel switch ONLook on the side of your dirt bike near the engine and locate the "FUEL ON/OFF" switch. Use your finger to move the lever to the "ON" position. Your dirt bike will not start if the fuel is turned off. This off switch helps prevent fuel leaks when your dirt bike is stored.
  • Step 312234_65x95_aspect.jpg Turn choke ONIf your dirt bike engine isn’t warm, you will need to turn the choke on to start the bike. Locate the choke lever near the engine on the side of your dirt bike, probably not far from the "FUEL ON/OFF" switch. Use your finger to move the choke lever to the on position. Once your dirt bike has started and the engine has warmed up, you will need to move the choke lever to the "off" position.
  • Step 412236_65x95_aspect.jpg Foot on kick start pegBend your knee and place your foot on the kick start peg while leaning your weight on your other foot. Stand slightly and push the kick starter all the way down with as much force as you can.
  • Step 512239_65x95_aspect.jpg Push all the way downIf the bike doesn't start after the first attempt to kick start it, try again. Remember to push the peg as far down as it will go with as much of your weight as possible.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If your dirt bike has a four-stroke compression engine and won't start, release the compression valve and try starting it again.
    • Sometimes, the engine remains in a compressed position and cannot turnover until the pressure is released.
    • If your dirt bike is equipped with an electric-starter, but won't start, you can follow these steps and kick start it.
    • Remember: always wear safety equipment when operating a dirt bike or ATV.
    • You should at least wear a helmet, boots that cover your ankles, and a chest protector to avoid serious injury.
    • Always supervise children when operating motor vehicles.
    hope this helps u
    please rate me.......................
    thank u for using fixya
    regards
    sivaranjini
    Nov 30, 2009 | 1992 Suzuki GSX 600 F (Katana)
    Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv Logo
    662 people viewed this question
    Top Champion International Electrical Supplies Experts
    Gene Haynes
    Marvin
    Marvin
    Are you a Champion International Electrical Supply Expert? Answer questions, earn points and help others
