Computers & Internet Logo
toby saul Posted on Dec 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell inspiron M5030 won't charge, green light is
Michael Kennedy
Level 2:
Novelist:
Champion:
  • Expert 233 Answers
  • Posted on Dec 24, 2012
Michael Kennedy
Expert
Level 2:
Novelist:
Champion:
Answers
233
Questions
0
Helped
48509
Points
310
The solution to your problem lies in one of the following three areas:
1.) Your dell inspiron m5030 charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Andy Bale
Level 2:
Sergeant:
  • Expert 213 Answers
  • Posted on Dec 23, 2012
Andy Bale
Expert
Level 2:
Sergeant:
Answers
213
Questions
0
Helped
32697
Points
781
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
4 Related Answers
mmnhltm
Mamoon Haltam
  • 695 Answers
  • Posted on Jun 13, 2011
SOURCE: my hp compaq turned
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
samaddar07
Avishek Samaddar
  • 639 Answers
  • Posted on Jun 16, 2011
SOURCE: My Dell Inspiron m5030 won't turn on. It was
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
Just try this and leave a feedback for next steps.
Anonymous
  • 318 Answers
SOURCE: Dell Inspiron m5030 won't turn
remove battery for 30 min and re insert and try re starting
Anonymous
  • 382 Answers
  • Posted on Sep 24, 2011
SOURCE: Describe your Inspiron M5030 15.6"
one possible cause would be the dead cell of your battery. One option is to buy new battery or just visit a store whose catering of repacking battery for laptop. Hope it helps thanks.
1helpful
Where is the lid sensor on a Dell Inspiron M5030?
1) http://www.parts-people.com/index.php?action=item&id=12015
2) http://www.ebay.ca/itm/Genuine-OEM-DELL-Inspiron-M5030-N5030-Series-Sensor-BD-10630-1-48-4EM19-011-DJ2-/261068854360?pt=LH_DefaultDomain_0&hash=item3cc8ea9458
3) Location;
http://en.wikipedia.org/wiki/Inspiron
Hibernation sensor problem,
http://en.wikipedia.org/wiki/Inspiron#Hibernation_sensor_problem
Dell Support > Inspiron M5030 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/insM5030/en/sm/index.htm
What condition is the Video Cable in? (Dell = Display Cable)
Continuity check with a multimeter prove it to be OK?
Regards,
joecoolvette
[LED backlighting, no screen Inverter used; for those who may think it is a screen Inverter problem ]
My dell inspiron m5030 won't boot up
hi
did you tried a reboot in safe mode,sometimes works
or if you have the repair disk,try it
thank u,a rating would be pleasurable
My N5010 dell laptop battery won't charge anymore. Could I just need a new battery, or charger, or could there be something else going on internally that I need to know about? For the most part, I
If your laptop is still under warranty, contact dell and they should be able to fix it free of charge, The same thing happened to my laptop a few years ago and fortunately, it is still under warranty, The fault is the charger itself which dell replaced free of charge.
My inspiron laptop m5030 will not turn on, and it does not appear to be charging when i plug it in
Try to change your adapter first. If still can't turn on. your laptop got motherboard broblem.
Thanks
1helpful
My dell inspiron won't charge if the OS is awake/on but DOES charge when it's off/asleep. this is a new problem.
This appears to be a common problem. Sounds like the current is not being shared while in use. If you know the battery to be good, I'd check the output voltage of the charger 1st and see it is putting out the right voltage. The chargers for the Mini series are weird, so may be worthwhile borrowing another charger to eliminate it from the problems.
After that... you may need to get the laptop checked by Dell
Grand Canyon Tech
Grand Canyon Tech
