Question about Jacuzzi Balboa R574 System for 1 2 Speed Pump Value 52221 05
Hot tub in EC with light flashing - Jacuzzi Balboa R574 System for 1 2 Speed Pump Value 52221 05
Posted by mrleo48 on
Lee Hudson
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
Ecn or Ec Message
Ecn or Ec Message
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Posted on May 09, 2013
Ec on hot tub codes
Can you NOT understand simple English. Where do I purchase liquid nitrogen?
Oct 12, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
On my hot tub control panel Balboa M1 is the code Ec?
Your spa is in Economy Mode:
Ecn or Ec MessageEcn or Ec Message
Mar 13, 2013 | Balboa Instruments Pool & Spa
What does ec mean on my hot tub
EC stands for Economy mode. This is a setting that tells the computer to check the temperature of the spa less frquently, as well as running fewer filter cycles. Spas should be set to EC while you are away on vacation or not planning to use it for a while
Apr 29, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
Tub is not heating to temperature and flashing a Ec message on the temperature screen.
the Ec message is reffering to the mode the tub is set for. Ec stands for Economy mode. In Economy mode the heater will only come on during the filter cycle you have programmed. It will take a while for the tub to actually heat up in this mode. Change the mode to St mode which stands for Standard mode. Your manual should explain how to do this. usually you hit the temp button then the light button to change from mode to mode. Once the St is in the read out window don't touch anything and it will except the programmmed entry automatically. In the Standard mode the tub will keep heating until the set temperature is reached. then it will come on every half hr or so to check that the temperature is maintained.
Oct 09, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Nov 14, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
WHAT IS THE MODE BUTTON FOR?
EC stands for Economy. Change the mode until you reach ST and then it will stop flashing and function as normal.
Economy mode only allows the heater to function when the hot tub is on its filtration cycle.
Regards,
Ian.
http://hottub.synthasite.com
Jan 04, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Jacuzzi Balboa R574 System for 1 2 Speed Pump Value 52221 05 Logo
318 people viewed this question
Top Jacuzzi Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
