Power abruptly died. Checked outlet and power there is OK. Pulled fuse on upper right front of unit and it is OK. Unit was manufactured in June, 2008
SOURCE: Ge microwave model #JVM1540SM1SS
Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
SOURCE: ge spacemaker microwave
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If it has a hood thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: GE JES1344SK01 countertop microwave, no power
for many reasons.
It
may be the fuse, which is usually located behind the grille or on the
floor of the oven behind the control panel or between the door switches.
If
the fuse is good, it may be an open thermostat or thermal cutout (TCO)
/ thermal fuse on or near the magnetron or on top of the cavity / body
of the oven.
When
checking TCOs or thermostats, if it has a hood fan thermostat,
that should read
If the cavity thermostat
needs to be checked or replaced you'll need to pull the oven from the
wall, in which case you can download GE
owner's manuals and installation instructions here.
If
it goes dead or blows the breaker (or GFI) when you plug it in or open
or close
mount.
You should do a
continuity test on
then test it again.
There
should be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very
helpful
when troubleshooting & testing.
helpful exploded view diagrams by entering your full
model number here. Once you have the part numbers, though, I would suggest ordering parts here at a much lower cost.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: No power to GE Spacemaker Microwave
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
