HP Compaq 8510p Notebook Logo
Anonymous Posted on Dec 23, 2012
Problem with HP 8510q laptop charging. Charging not working. Laptop working only that time when i have power in battery. Charging light not show. I try other charger but same problem. Is it inside some fuse or what is the problem?
joecoolvette
Level 3:
  • HP Master 5,660 Answers
  • Posted on Dec 23, 2012
joecoolvette
HP Master
Level 3:
Answers
5660
Questions
0
Helped
2193487
Points
18014
Inside? Yes. (If 'charger' is good)
Fuse?
No
Diagnostic flowchart:
A) AC adapter (Charger), has to be KNOWN to be good, before going on.
Used on a working laptop to see, or multimeter is used to check Voltage (DC)
The plug end that goes to the laptop, from the AC adapter, has a Center Hole, and a cylindrical outside metal shell.
The Function knob is set to DC Voltage. If just a symbol, the symbol is a dotted line over a solid line.
If more than one DC Voltage scale, the Function knob is set to the 0-50 Volt DC scale.
The Positive (Red) probe lead of the multimeter goes to the Center Hole, and the Negative (Black) probe lead of the multimeter, goes to the cylindrical outside metal shell.
You should be reading 19 Volts DC.
Also have an assistant gently wiggle the cable FROM AC adapter TO laptop, and the power cable TO AC adapter.
If there is a fluctuation on the reading, there is a broken wire, or wires, in one of those cables.
B) Check the DC Power Jack.
This is the jack on the laptop (DC_IN) that the AC adapter plugs into.
Has a Center Pin, and an inner cylindrical metal shell.
Battery removed, use an eraser on the end of a No.2 pencil, and see if you can GENTLY wiggle the Center Pin around.
ANY perceptible movement of the CENTER PIN, means replacing the DC Power Jack,
(By the way, is it an 8510p, or 8510w?)
http://www.alldcjacks.com/en/ppj052-laptop-dc-power-jack.html
Any movement of the rest of the DC Power Jack (Body), means replacing it; or may just mean the solder joints are cracked, and can be re-soldered.
C) AC adapter and DC Power Jack checks out?
Problem may be with Power MOSFET's on the motherboard, and associated MLCC's.
(Multi-Layer Ceramic Capacitor, and they are SMD/SMT just like the Power MOSFET's.
Surface Mount Device/ Surface Mount Technology)
Using HP pavilion dv6000 series, and Pavilion dv9000 series Notebook PC's, for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Or, it could be worse,
http://koti.kapsi.fi/jpa/stuff/pix/travelmate_6292/
Regards,
joecoolvette
  • Anonymous Dec 26, 2012
    Allright, i must check those tips first. Thanks for help. I tell later hows going..
  • joecoolvette
    joecoolvette Dec 26, 2012
    OK. I'll be waiting. Regards, joecoolvette
5 Related Answers
thejus
Thejus Mt
  • 30 Answers
  • Posted on Jan 19, 2008
SOURCE: HP Pavilion DV1000 not charging the battery
yes its u r mother board battery connector problem...in the mother board there is IC for sensoring DC supply..near the battery connector..plase check the IC is working properly with A logic probe.if it not working plaese replace the IC with a blower..
Anonymous
  • Posted on Mar 03, 2009
SOURCE: hp power supply failiure
Ive worked on a friends G7000 series laptop, since it had the same symptoms you have with yours.
I tested it on my own(identical) working charger/PSU and still no charging.
After taking the motherboard out, i traced the fault to a short circuit FET (field effect transistor) with the PCB reference of PQ1, located right next to the connector for the DC power jack loom.(short from gate to source) The FET is made by Fairchild Semiconductors and its part number is FDS6675BZ. Being in the UK, i ordered the part from www.farnell.co.uk at a cost of 56pence. After changing this FET(which is there to control power) the laptop is working.
If you are not good with very intricate surface mount soldering, then i suggest you buy the component, take the motherboard out of the laptop(not too hard) and take them both down your local TV repair shop for them to check and change it(tell them the board reference PQ1).. shouldnt cost more than £20 or so been as they dont have to fault find.
Martin
martinkwashere at hotmail dot com
Anonymous
  • 107 Answers
  • Posted on Jul 05, 2009
SOURCE: compaq HP 6715s Laptop not charging!
If you can determine that it is not the battery just going bad, then most likely it is a problem with the motherboard. I actually have this same problem, and have not been able to find a quick fix.
HP has a battery tester tool. If you are able to use this, then you are one step ahead of where my HP laptop is. I tried running this and it insisted that I did not have a battery installed, or that it was dead. If you have this same problem, then it looks like it might be time for a new motherboard.
In anycase, it might also be worth the time to try draining the battery completely and attempting to charge it back up. According to a few other sources, the laptop can sometimes get confused and think that a full battery is calibrated to be a low battery.
Anonymous
  • 210 Answers
  • Posted on Aug 20, 2009
SOURCE: hp laptop unable to start
Hi if you flip your laptop may see that there is a squared cover with two screws remove the two screws and the cover at this time you will see the memory card it might be two or one remove the memory card make sure not touch the connector side of the memory. if have pencil eraiser clean the memory card connectors and clean it again with cotton bud with alcohol let dry. Reinstall it back and turn on you laptop. if this will not work your hard driver is the problem. Hope this info will help you solve the problem.
HH
Anonymous
  • 2567 Answers
  • Posted on Sep 23, 2010
SOURCE: my hp compaq laptop charger is not working in the
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
2answers
Hp laptop trouble with power on
There could be several reasons why your HP laptop is not turning on and not charging even after installing a new power button board and DC in port. Here are a few possible causes and troubleshooting steps you can try:
Battery: Even if the laptop is connected to the charger, if the battery is faulty or dead, the laptop may not turn on. Try removing the battery and plugging in the charger directly to the laptop. If the laptop turns on without the battery, then it's likely that the battery needs to be replaced.
Charger: Check if the charger is working properly. You can try using another charger with the same voltage and amperage to see if the laptop starts charging. If the laptop starts charging with a different charger, then your original charger may be faulty.
Power Jack: Make sure the power jack is properly connected to the motherboard. If it's loose or not properly seated, the laptop may not charge or turn on. You can try reseating the power jack or replacing it if it's damaged.
Motherboard: If none of the above steps work, then the problem may be with the motherboard. A damaged or faulty motherboard can prevent the laptop from turning on or charging. In this case, you may need to take the laptop to a professional repair technician or consider replacing the motherboard.
In summary, the laptop may not turn on even when connected to the charger if the battery is dead or faulty, the charger is faulty, the power jack is loose or damaged, or the motherboard is damaged. It's important to troubleshoot each of these components to identify the root cause of the issue.
So I bought a HP Pavilion tx2510us about 5 years ago and it served me well for the time being, but about a month ago I was using my laptop and I noticed that the battery icon showed it wasn't being...
You might check your device manager to see if there are any clues there before trying a new battery. Also, check your Power Options settings and see if there is a conflict.
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Sir i have problem in hp charger or battery i don't know but when i charge my laptop at that time yellow light beside laptop which shows charging but after some time it is just simply plugged in a
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Battery light dosent work during charging or fully charged. Light comes up at times. battery level is either not indicated properly
In most models the battery light is displayed when it is charging with a possible blinking when it nears charging and it cuts off when the charge is full.
So if your laptop shows that the battery is charging in the task bar- bottom right, then you can ignore the issue unless your laptop is in warranty and it can be done free of cost.
If you open power options in the control panel the charging will be displayed , if this show Ok then the fault is the hardware circuit issue on the mother board power section.
2answers
My HP Pavillion dv6000 shuts down with battery in, runs on power no problem for quite sometime; w/batter it shuts down. Is it the battery? I called HP and they said I would have to bring it in for...
when battery is in if laptop shows charging (charging light blinking on laptop) then battery is faulty.
but charging not shows properly then motherboard is faulty.
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
