My Sony triniton tv won't power on because the
Posted by jenniferd528 on
SD Tech
    Top Expert:
  • 14,553 Answers
Every set has a standby power supply that runs 7/24 when set is plugged in---it means in this case a main power board or something associated with that is not working, Set is not making it from just standby to full on.
Posted on Dec 23, 2012
5 Related Answers
Anonymous
  • 34 Answers
SOURCE: How do I tune in Sony Triniton tv please
Hello
The first thing is to try going in the tv's menu
It should be similar to this:
Menu>setup>channel setup
once you find something similar, run the channel setup and it should add in the channels
If that doesn't work, screw on the cable wire, unplug the tv for a good few minutes, then replug the tv and it should automatically scan
Hope this helps
-Chris
Posted on May 01, 2009
Alleluia
Stephen Kamm
  • 69 Answers
SOURCE: sony triniton KV- XG29M30 WONT TURN ON
I had a similar problem a few years back . I purchased a new on/off switch from Sony and that seemed to fix things.
Alleluia
Posted on Jan 06, 2008
Anonymous
  • 59 Answers
SOURCE: Sony TV stuck in stand by mode
the 9 blink code is caused by a bad diode on the pc board. The zero crossing detect circuit is not allowing the power supply to come on .
Posted on Oct 02, 2008
Anonymous
SOURCE: Sony Trinitron XBR, Stand By Mode?
Many of the later model Sony TV?s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it. The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again. Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article. Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open). Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. One blink - not used for the self-diagnosis Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive). Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Posted on Jun 14, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: My sony triniton tv won't turn on. The standby red
HI. this may be a fly back situation. this is a transformer that is located on the power board section of your set. This device stores and, distributes the necessary AC current needed for proper CRT performance. There is also a horizontal deflection chip that will shut off the transformer if it becomes unstable as well.
I recommend checking the Horizontal deflection chip for damage. if this chip is in good condition, replace the HV Fly back transformer.
Posted on Jun 25, 2009
Sony triniton won't go above channel 125
Do a factory reset. Visit this site for more details.
Mar 17, 2013 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trnitron tv won't turn on. stand by light blinks. Any ideas?
watch the blinking light---if a specific sequence like 7 blinks a pause and repeated endlessly that is a error code. It will not point to a specific part but will indicate where the issue might be.
Dec 19, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Emerson tv....won't turn on...stand by light won't go off
Not making it on or out of standby---first place to look is the power supply for signs of damage or puffed up filter caps there.
Dec 10, 2012 | Emerson SLC195EM8 LCD TV
Sony blinking codes
If i remember correctly ten blinks means a high voltage error.
The only thing you could try is unplugging the power cord then plug it back in and try turning on the tv. If it still won't turn on try unplugging the power cord for five hours or longer and try again. If it still won't turn on it would be best to find a local repair shop that works on sony tv's and have them repair it for you.
Mar 01, 2012 | Sony Grand WEGA KDP-51WS550 51" Rear...
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Why does the sony triniton 40in not turn on but the power button flickers red
Is it blinking a code? * * * * * * * * * * * * This would be a 4 flash. Count them and post the flash code.
Mar 17, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Stand By timer light continues to blink on Sony Triniton TV
That problem comes up when one or both of the convergence IC's are burnt ... it normally has an "STK" number on it screwed onto some large aluminium heatsink ..... however if you venture to change it get back to me ... I'll try to guide you through ....
May 23, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
Top Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
