DeLonghi PAC W130 Portable Air Conditioner Logo
Posted on Dec 23, 2012
What does CL with a tragle and ! mean - DeLonghi PAC W130 Portable Air Conditioner
1helpful
2answers
Bosch dishwasher start with CL code
That is just saying the Child Lock (CL) has been activated.
Deactivate the child lock ' Bosch
Bosch Home https://www.bosch-home.com > ... > Get support
1. Press and hold the start button for three to five seconds ... When the child lock is activated, there will be a message "CL" in the display and all the washing ...
Bosch dishwasher child lock problem
Bosch-home.co.uk https://www.bosch-home.co.uk > ... > Dishwashers
Hold down the lock button for three to five seconds. You should hear an audible beep and/or see the symbol disappear. The child lock is now deactivated.
What does CL mean on a dishwasher? And how do I fix it?
Quora https://www.quora.com > What-does-CL-mean-on-a-dish...
This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ...
9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
How to turn off the CL on the display of a bosch dishwashe...
JustAnswer https://www.justanswer.com > Appliance Repair
Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone.
1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your
..https://www.youtube.com/watch?v=Xr4DBwACUW4
1helpful
I have a Canon Pixma MG printer . There's orange lights at BK & CL that are blinking? What does that mean ?
means that the toner cartridges are just about out of ink and need replacing
BK=black and CL= color
3helpful
On an LG front loading washing machine, what does the code CL mean?
Hi Emma Haigh,
CL means Child Lock, please follow my below Tip on how to remove the setting:
L.G CL ERROR/CODE
Kind Regards
JEDMEYER1
* If you found this solution helpful, please rate it
2helpful
Flashing CL?
A flashing CL means that you have to set the clock.
The washing machine doesnt start at all. The displayer says: CL.
CL means "means chils lock" to disengage hold temp and echo/rapid together and this should solve the problem
CL code
I'm getting CL too, and don't know what that means, but I DO know how to get your remote phones to work. Before I lost the manual I had to do that. Simply set each one in the main charger for about 20 seconds and they will work.
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
7helpful
2answers
Error Message CL in the front panel
Error message CL solved. CL means child lock. To deactivate press two linked buttons (on my machine the right options button and the temp button) together for a couple of seconds.
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
