Using Samsung Galaxy S3 and Samsung Galaxy Express phones, says connected to wi-fi but why does it still say scanning and why is there a lock on the symbol to the right?
SOURCE: A friend has a Thomson TG782t connected via
When you connect the ethernet cable, you are able yo go online. but notwireless . you need to make sure that your computer is connected to thewireless network or not ?
Click Here for more info about wireless connection.
SOURCE: my laptop wont connect to the internet by my
hat is the Operating system on the laptop ?
Are you getting any error message when you try to connect to the wireless network ?
If there is any other wireless computer aleady online then the router must be working.
If there is no other wireless computer connected tp the network then check the wireless settings of the router.
Click Here for more info about how to connect to the wireless network
SOURCE: unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
SOURCE: Very, very low signal wi-fi connection with iPod
Are there any other Wi-Fi networks at the area? I suspect interferences in the channel. Log in the router's page, locate the wi-fi settings and change the channel from automatic to manual and select any of the 13 channels (usually). Check the result. In case of problem existing, change channel again until you find the better reception from the iPod.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution. Please consider leaving a 4-thumbs rating; I'd appreciate it greatly.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
SOURCE: I HAVE A PANDIGITAL NOVEL
Some routers come preset with a network key, others can be manipulated. many have driver issues when dealing with newer Pc's
Are you getting internet through a wired connection from the router? or is this strictly a wi-fi issue?
