I have all original cables, how do i connect it to my vizio tv
SOURCE: trying to connect my xbox
hook it up in place of the cable box...rf adapter or use the rca plugs and get barrel adapters to connect them
SOURCE: original xbox need to connect to new tv no instruction book
all xboxes come with 3 different dvd drives
Samsung, Philips and Thomson .
the Samsung seems to be the best drive out there as i have 2 xboxes that are 5 years old and not a problem at all
you can read more here :)
http://www.instructables.com/id/Replacing-an-XBOX-DVD-drive/
or if you want i work on them just email me what you want to do on this
[email protected]
SOURCE: cannot connect original xbox to pc ..........
ok here u go man, first off u need this program FlashFXP, then download it and install it, then start it with ur xbox and pc hooled up to a ROUTER the program will ask a question u select accecpt, then got to ur settings and u will need to turn passive mode OFF, just check threw all the options, i checked to see if my passive mode had any effect didnt seem too but it does make adifference when u first start. ok so the program is running, you will see a lighting symbol on the right section click that and chose quick connect, no if you havent changed your ip on the xbox to auto it should ne like this
IN SERVER OR URL PUT THIS; 198.168.0.2 yours maybe different so plz check your xbox info to see its ip,
then u have to type in a name and password, xbox and xbox are the username and password,
Username; xbox
password; xbox
then on the left column u will see your stuff simply drag and drop the items you want to the correct area in your xbox MAINLY E. and also make the file isnt to long as FLASHfxp wont transfer those files with too big of a name
