SOURCE: Liteon 5045 problem in playing normal movie DVD's
The DVD drives are very unreliable and just get more temperamental with age. I replaced mine with a Lite-On SOHW-1213S. The DVD is too big to fit in the old ones place so it sits on top of the unit with the cable going through the slot, but it works brilliantly.
SOURCE: Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
SOURCE: Liteon dvd recorder won't play or record from disk or cable tv
You should be able to connect with the AV input, Y, Video R, W. Audio, they go to same color on DVD & TV.
Testimonial: "Totally worthless"
