Mitsubishi WD-73732 73" Television Logo
mike belcher Posted on Dec 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Color fading out wd-73732
Replaced bulb still color fades out afer 20 min. or so.
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Dec 23, 2012
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718790
Points
48227
Try the soft reset with the remote: menu,1,2,3 and enter.
5 Related Answers
Anonymous
  • 146 Answers
  • Posted on Nov 20, 2008
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
You need to replace the "light engine". This is very very difficult. You need to take it to a repair shop. But this will be very expensive. Around $1,000.00
Anonymous
  • 184 Answers
  • Posted on Feb 14, 2009
SOURCE: Mitsubishi WD-73732 has 1 inch blue/purple band at screen top.
Is this a DLP or LCD projector?
Anonymous
  • Posted on Mar 02, 2009
SOURCE: color fades out on tv
I have the same tv and the same problem (color banding, incorrect colors, colors blinking) occured after I replaced the lamp. I had a tv repairman take a look at my unit and he said the color index was incorrect, the tv doesn't know the correct colors to display. The best way to fix that problem is to replace the "light engine". The repairman replaced the "light engine" to my tv and everything is working great. My tv was still until warrenty so I don't know how much a new "light engine" would have cost.
Anonymous
  • 616 Answers
  • Posted on Nov 07, 2010
SOURCE: replaced lamp and
color or brightness? need to be specific.
Anonymous
  • 1779 Answers
  • Posted on Nov 10, 2010
SOURCE: I have a 2 year old Mitsubishi WD-73732 - 1080p
It will cost you probably in the area of $700.00 to replace the Light Engine. I don't think it would be a good idea to repair it. DLP sets have been out of production a few years now due to high failure rates of the light engines for all makes and models and the consumer cost for the lamp.
I have a dlp 73in mitsubishi tv and i have sparking in the long box next to the bulb housing
check to see if the lamp connectors inside the lamp compartment didnt get pushed back inside the set. If they are still there secure inside the lamp compartment then you will need a new ballast which you can get from www.tvrepairworld.com
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Where can i find a color wheel for a 73732 mit
The way that you change the color on this TV is thru the audio/video menu, under Perfect Color. It show you how in your owners manual on page 74. If you no longer have the owners manual you can downloaded it here http://www.mitsubishi-tv.com/pdf/ownersguides/WD-73732.pdf
The color has faded . I replaced the bulb the problem persists!
Light Engine is Bad, If you had said TV was making loud whistling sound then it would be Bad color Wheel
2answers
Can you help me with my TV problem???
Sounds like your color wheel may be at fault. Do you ever hear any unusual noises coming from the rear of the TV? Color Wheels usually make a humming sound as they go bad. This is because the tiny bearings in the color wheel motor have begun to misshape from use and heat. Your TV may have a new type color wheel assy that has a slightly different configuration but the result is the same.
michtech
1helpful
2answers
Color fades out on tv
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
