Question about Bosch Axxis WFL 2060 Front Load Washer
Need instructions to stack Bosch Axxis washer & dryer - 24"
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 79 Answers
Posted on Feb 28, 2013
    New Friend:
  • 97 Answers
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Posted on Dec 22, 2012
5 Suggested Answers
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Bosch axxis washing machine detergent symbols
There are usually 3 compartments in the drawer, the smallest is for using fabric conditioner, the largest is where you put the powder or detergent in, the middle size one you do not put anything in, as it is where the cold water comes in for rinsing.
Plz rate my solution.
Thanks.
Posted on Jan 26, 2009
Anonymous
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Posted on Jun 30, 2008
bubba bass
  • 14 Answers
SOURCE: Can you supply me with instructions for a Bosch washer/dryer
Bosch Product web site.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Click on WVTI2840GB/04 for info.
The model number has the letter "I" not "1"
Posted on Mar 03, 2009
uniman9310
Mike
  • 190 Answers
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
Posted on Jun 03, 2009
Anonymous
SOURCE: Bosch Axxis Washer Detergent slot codes; what do they mean?
soap goes in far left
softner middle
liquid all fabric bleach or powder bleach in far right
Posted on Jun 24, 2009
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
Can I stack a Bosch WTL5400 dryer on top of a Bosch Classixx 7 washing machine?
http://www.bosch-home.co.uk/store/product/Connectionpiece/244024
Call the helpline for verification of compatibility prior to ordering.
Feb 06, 2013 | Bosch Axxis WTL 5400 Dryer
Dryer spins, but no heat & then shuts down!
The heater coil is not getting hot. IT coulb be burned out or it could be a thermostat or thermal fuse that has failed.
Dec 06, 2012 | Bosch WTZ11310UC NA AXXIS Stacking Kit for...
Can you stack if they weren't designed for it?
ive seen people build there own stack unit. alot of techs will tell you no but ive seen this done and there has been no issue. just make sure your platform is strong enough to handle the tumble of the dryer during normal operation
Jun 24, 2009 | Bosch Axxis WTL 5410 Electric Dryer
How to un-stack Bosh Washer WFL 2060/Dryer WTL 5410
Did you ever get an answer? I have the same problem...
Mar 21, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
858 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
