It will not connect to 3g at all and i have even deleted all apps that i have downloaded thinking it would fix it but still nothing....
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
SOURCE: my zte warp is not disconnecting from calls and not receiving 3g
your phone have software problem and u need update it
SOURCE: zte warp got wet
When this happens, immediately remove the battery. Let the phone dry (it may take several hours) before you put the battery back in and try to turn it on. If it is only water, and you act quickly enough, your phone may be okay.
SOURCE: my new zte v9 wont connect to the Internet
you can access the Internet through the mobile network or via Wi-Fi.Your mobile network settings are pre-configured by your serviceprovider and there is no need to change any settings. Wi-Fi Wi-Fi provides wireless Internet access over distances of up to 100meters.1. Tap Home > Settings > Wireless & networks .2. Select the Wi-Fi check box to turn Wi-Fi on
