Crock Pots & Slow Cookers Logo
Posted on Dec 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can the inside pot go in the oven?
Pot is blue with a glass cover
Anonymous
Level 2:
Sergeant:
  • Expert 475 Answers
  • Posted on Mar 16, 2013
Anonymous
Expert
Level 2:
Sergeant:
Answers
475
Questions
0
Helped
112433
Points
908
Yes if your going to keep thins just warm but not to cook in.
1helpful
Substiture for broken infrared oven glass bowl
Pyrex or Corning Ware Bowl yes, no problem. Not a crockpot, as they are simmer temperature only.
You can also Google
make model bowl replacement
https://www.google.com/search?q=infrared+tabletop+oven+replacement+bowl
I love the crockpot but the "plastic" handle broke
Check ebay. Sometimes they have glass covers for some models.
1helpful
Can we put our 6.5 crt. bravetti crock in the oven because we started our scallop potatoes to late.
Hi there, I would say if it has the removable ceramic insert that you can remove from the base, it can be put in the oven. Generally all of the crock pots I have ever had or seen do have the removable ceramic pot with a glass lid. Yes these crocks can be put in an oven. Hope this helps.
Is this model of west bend crock pots oven safe? if so, to what oven degrees and with the lid on or off?
The Instruction Manual for your product is available here:
http://www.westbend.com/supportdata/L5531B_5-6Qt%20CrkryCookers_ALL.pdf
Under the section on Heat Precautions you will note:
Do not use the cooking pot or cover on the stovetop, under the broiler, in the freezer, or in the oven. You may use the cooking pot in the microwave oven, but do not place the glass cover in the microwave oven as it has a metal ring.
Sorry someone has not responded sooner.
2helpful
3answers
Dropped and broke cover for Rival crockpot model SCV401 need a replacement cover.
Rival Glass Crock-Pot Lid Oval
Fits Rival Crock-Pots using a solid oval glass lid cover
Lid Measures approximately 12-1/4" x 9-5/8" from end to end
Lid is glass with a metal rim
If this sounds like it click on the web link below
http://buyitnow64.stores.yahoo.net/ricrpotslcog2.html
OR IT COULD BE THIS ONE
Rival Crock Pot Slow Cooker Replacement Round Glass Lid Cover
Works with Rival Crock Pot Models:
3300, 3302, 3305, 3351, 3350, 3355, 3504, 3520, 3550, 3500, 3654, 3656, 3760, 3845, 3850, 3950
Approximate total diameter: 10"
Use model number NOT measurements for the correct replacement part
PLEASE NOTE: If your model number has a slash or a hyphen and another number on the end of the numbers above (ex. 3300/2), then this lid will NOT work.
If it sounds like this one click on the weblink below
http://buyitnow64.stores.yahoo.net/ricrpotlidre2.html
Hope this may help.
I had the exact same thing happen!
First some common sense, there is no such thing as partially defrosted - it's either frozen or it isn't as far as cooking safety. A slow cooker, even on high, only takes food to simmering temperature and holds it there, and it does it very slowly. Put something frozen inside and cover with glass, the glass gets very cold and then turn it on high and go away for several hours....unless the glass is Corning Ware and rated for freezer to oven, expect it to break one out of ten times. Also, putting frozen food in a slow cooker and thawing while slow cooking gives you a good chance at growing some unhealthy bacteria in the cooker as the meat warms. Meat should always be thawed fully before placing in one of these units, as the directions specify.
Need a handle for the lid
I have seen this so many times you'd think rival would improve the handle with a better material...
I used a cover handle from a glass covered sause pan, you can get them at the dollar or thrift store- much better handle anyway.
I do not recommend using a drawer nob with teflon washers and a screw that you can get from the hardware store- the threads of the screw may (will) come in contact with the glass and the glass will break.
use a handle from a glass covered pan you already have or spend the 3 - 8 bucks at a dollar or thrift shop, and throw the pan out. it will be worth it just in less agravation and having a functional tool...
20 Qt. Mod: RO220 Roaster Oven
MY CROCK POT PLATE IS BROKEN, I WOULD LIKE TO KNOW IF I CAN REPLEACE IT, AND IF A NEED AN US ADDRESS OR IT CAN BE MY ADDRESS IN MEXICO. AND THE COSTS. THANK YOU.... MY MODEL IS 5855 OVAL PROGRAMABLE. THANK YOU LUCY
10helpful
3answers
Crock pot dish in the oven
1-800-323-9519 Rival's phone number.
From the horses mouth: The stoneware insert can withstand 380degrees fahrenheit, sans glass lid.
You are fine.
Lid handle
I found the site www.crock-pot.com has all the replacements for Rival. the 800# is 1-800-323-9519
Top Rival Crock Pots & Slow Cookers Experts
Paul Carew
Paul Bade
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
