I have a similar problem. I found a crack in the tank. I am trying to find out if it is cheaper to replace the tank, or just buy another one. I have tried other types and like this one the best.
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
Generally a shut down is due to an empty water container or the float valve. If you have a can of compressed air, you can blow dry the integral ports and perhaps free up any contamination that has caused the unit to shut down.
The tubing to the mouth of the dolphin or the misting nozzle is clogged with mineral buildup and scale. To clean this, do the following.
Empty the water in the tank and replace it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow the unit to sit for 30 minutes, then turn it ON. If mist does not appear within 10 minutes from the mouth of the dolphin. Turn the unit OFF and allow it to soak over night. In the morning, turn the unit ON and allow it to run. Once the mist appears where it should, run the unit until the tank is half empty. Then empty the tank of the remaining solution and refill with Bottled Distilled Water and run the unit until it is empty. This will flush all the remaining solution from the tank, tubing & nozzle.
In the future I would recommend using Bottled Distilled Water on a regular basis, rather than tap water. Doing so, will eliminate the problem of scaling.
Hope this helped you and thanks for choosing FixYa.
The unit may simply has a calcium scale build up and it's blocking the water passage. To clean it, empty in water remaining in the tank. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water and fill the tank. Allow it to soak for at least one hour, then turn the unit ON. Place you hand in front of the misting nozzle to see if it's working. If you don't feel any mist, turn the unit OFF and allow it sit over night. If you do feel mist, allow it to run until the tank is 3/4's empty Turn the unit OFF, pour out the remaining solution and refill with Bottled Distilled Water. Run the humidifier until it's empty. This will flush the system entirely. In the future, I would recommend you use Bottled Distilled Water, instead of Tap Water. If you do, you won't have to descale the unit any more.
The humidifier may be clogged with a calcium scale build up. Especially, if you use well water or your municipal water supply has a high chemical content.
To solve this problem do the following. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water (enough to fill the tank). Empty any water that is currently in the tank and fill it with the 50/50 solution. Allow at least one hour, before turning the unit ON. After turning it ON place you hand in front of the mist nozzle to see if any mist is being generated. If it's generating mist, allow it to run until the tank is 3/4's empty. Then turn the unit OFF, unplug it and empty the remaining solution. Refill with Bottled Distilled Water and run until the tank is empty.
If the unit did not produce mist after one hour of soaking, allow it to set over night and then follow the procedure above. Generally, an overnight soaking will do the trick. In the future, I recommend using Bottle Distilled Water rather than your tap water.
Hope this helps you solve the problem. Please let me know. Thanks.
It may have a scale and calcium build up. Particularly, if you use well water.
To clean it, unplug the unit and empty in water that is in the tank. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water (enough to fill the tank. Pour the solution in the tank and allow it to set for 2 hours. Then turn the humidifier ON and place you hand in front of the misting nozzle , to feel if it's working. If it is, allow it to run until the tank is 3/4's empty, Empty te tank of the remaining solution and refill the tank with more Bottled Distilled Water and run for an hour. This will flush the 50/50 solution out of the system. It it wasn't working when you first tested it, allow it to set over night and try again the next morning.
In the future, use Bottled Distilled Water rather than tap water.
95% of the time, this will solve the problem. I hope this helped you. Please let me know.
I haven't had any problems with my Vicks Cool Mist Humidifier other than the fact that the area surrounding it is slightly wet after operating for a couple of hours....While I understand that I was using this to moisturize the air during a cold, I knew this would happen, because the air in my room is not dry. If the room isn't dry, the mist that it's putting out in to the air has no where to go but surround the humidifier. All I did to stop this was to buy a water proof mat. I suggest you do the same -- Also, in regards to the water smelling -- You should be cleaning out and drying the basin after every use. Water shouldn't smell unless you let it stagnate inside the plastic -- Try running distilled vinegar through the machine for a couple of minutes -- Also, I would use an extension cord and let it run outside so that your house doesnt smell like Vinegar.
