Got it from a friend as a hand me down. everything on it was good and functioning. i wanted to restore so its my name and information and files . not his stuff. so we do that and now it wont even power on or anything. i mean nothing....
SOURCE: mac desktop
Enter the name he used,collect all your work put it in a folder called my stuff drag this folder to apps. Then change it back to your name. Look in apps for your stuff.
Jerry
SOURCE: Lost Desktop
You didnt change the administrator, you added a profile. SO all the stuff you were using is still in your friends name. You will have to go in as the administrator under his name, and put all your stuff on an external and log back in as yourself and put it on your side.
1. LOG OUT - Hit apple in top left corner, select log out, it will bring up 2 profiles, go in that way.
2. SYSTEM STARTUP - on desktop in whoever's profile click apple in top left, preference and then startup disk, select your profile and it will go to you all the time. Hope this helps.
SOURCE: e mac freezing all the time and won't read restore
Many eMacs sold between April 2004 and June 2005 are susceptible to age-related problems with freezing, startup failure, and scrambled video, due to a shipment of faulty Asian capacitors at the time they were built. Affected units include the following three serial number ranges: G8412xxxxxx – G8520xxxxxx, YM412xxxxxx – YM520xxxxxx, and VM414xxxxxx – VM518xxxxxx. The three-year extended warranty for this failure has expired. The Apple-standard fix requires motherboard replacement, probably uneconomical for this vintage machine. There are techs who will replace only the capacitors, for a lower fee.
Instructions
Back up any important files already on your G4's hard drive. A factory
restore completely wipes the system of all files you've created so, if
possible, make sure you have another copy of all your files, images, music,
etc.
Connect your G4 to its charger. Restoring the computer is a delicate
process that erases and reinstalls the most basic and important files of your
system. If the computer runs out of battery before the restoration is complete,
files may be damaged or left uninstalled. The result of this varies from having
to restart the process completely to permanent dysfunction of your computer.
Play it safe. Make sure you have plenty of battery left and the computer is
plugged into the wall.
Locate your Mac OS X Install CD/DVD. If you have lost the original disc
or never received one (a common problem when purchasing used computers), there
are a few options to consider. The first is to ask around; if you have friends
or family with a Mac computer they may still have their CD. It would be usable on
your computer. If this option fails, look online for a download of the
installation CD. Some sites offer installation CDs for all kinds of computers,
including the G4.
Insert the install disc into your computer's disk drive. Once visible,
click the "Install Mac OS X" button. Follow the on-screen prompts to
set up your computer preferences and begin installation.
Select a destination disc for the installation. This is typically the "Macintosh
HD" icon. Next, click "Options," and follow the rest of the
on-screen prompts/instructions. After this, the software is installed. The
computer should reset itself or can be manually reset by holding down the power
button twice.
