hi Robert.
Check it out (from Palmistry and Hand Analysis): There's an old superstition that when your palms itch it means money. An itching left palm means money to be paid out, while an itching right palm is money coming in. To stop the left palm from itching, the superstition says to rub the palm on a piece of wood. What does it mean when your left hand is itchy?
WHEN YOUR LEFT PALM ITCHES, YOU WILL GET SOME MONEY; BUT IF YOUR RIGHT PALM ITCHES, SOMETHING BAD WILL HAPPEN. IF YOUR PALM ITCHES YOU'LL HAVE MONEY. IF A PERSON HAS ITCHY PALMS, HE IS GOING TO COME INTO MONEY.
What are the causes of hand itching?But sometimes, itchy hands and feet can signal another health condition. Psoriasis happens when skin cells grow too fast and then pile up on the skin's surface. ... There are a few different types, and itchiness of the palms and soles is a common symptom.11 Jan 201 7What's Causing My Itchy Hands and Feet? - Web MDwww.webmd.com/skin-problems-and-treatments/hands-feet-itch Search for: What are the causes of hand itching?
Try to use cleaning tape there is must be dust on video head.
First use cleaning tape for 5 secound then play you tape if its not ok then use more 5 secound.
After that check your recording tape hope fully it will work.
first you have to clean video head must be some dest goes in side.
try to use cleaning tape.
first you clean 5 secound if have still lines then use more 5 secound hopefully problem sloved.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Hi the most common problem i have found here is that although the tapes look OK, they are very tight in case to go forward/back. Banging on the side of the cassette fairly hard on a flat surface a few times, both sides, quite often get rids of it. If that doesnt work, then will need a service on machine. Also try a new cassette..
