Samsung 2233RZ going black after 1-2sec
Starts the screen and it shows the background image for 1 to 2 seconds then the picture becomes black. Start it again and it does the same thing again. I have opened the screen but do not see any capacitors that are clearly broken. Could it be the mainboard? Or should I replace all capacitors on the psu anyway?
Posted by jays112 on
  • jays112
    jays112 Dec 22, 2012
    Forgot to say that the power light remains on when the image is black
  • jays112
    And now i have confirm that it is the backlighting. Any ideas how to fix that?
Sudeep Chatterjee
  • 3,267 Answers
First if you can, try the monitor with other PC first to make sure it is not the PC problem.
If it behaves in the same fashion, then most probably has dying power supply due to bad DC filter caps, just see the top side of the caps to ensure it has not bulged up distorted.See the images bellow
Samsung 2233RZ going black after 1-2sec - 12_24_2012_5_33_15_pm.jpg OR
Then there is the logic board. Plug the monitor in but do not activate the power switch so the backlight inverter circuits will be off. Check the 5vdc and the 12~24vdc to make sure they are OK. They should be tested with the load, you can use 6V 1A (6watts) lamp for the 5vdc, and car lamps such as 1157 (12v 8watts lo/26watts high) turn signal brake lamp using high filament connection for testing the 12~18vdc (or use two 1157 in series for 19~24vdc) for the backlight inverter circuits.
If the power supplies are working, the output voltages should be steady at the rated voltages. The power supply will go into shut down if it detects too much current draw due to false in the power supply or short circuits in the backlight inverter or in the logic board.
The backlight inverter circuits:
It takes the 12~24vdc and converts it to high frequency AC to drive the inverter transformers CCFL (Cold Cathode Fluorescent Lamp) assemblies. The transformers will drive the CCFL by applying the start up voltage (around 1500~2000v), when the CCFL start conducting, the voltage will drop down to about 500~800v.
The inverter has detection circuits to detect open circuit if the lamp is not attached or does not fire up after the start up voltage is applied, it will go into shut down. It will also shut down if the lamps draw too much current due to ages (when lamp gets old it will draw more current).
The inverter gets two signals from the logic board, one is the backlight ON/OFF signal, the other one is the Dimming signal for the lamps.
Common problems:
Bad filter caps, resonant caps (in the inverter output circuits), blown transistors/IC, shorted or open transformer winding.
If you are confident with your skill then go ahead else go to an authorized outlet for repairing
Do write back if you face any difficulty while working on the monitor
Posted on Dec 24, 2012
2 Related Answers
Anonymous
  • 10 Answers
SOURCE: MAG Innovision LT2219WDB monitor will turn on
I have the same problem with a customer's monitor (LT716S); it turned out to be damaged power supply board. As I understand it, MAG has a 3 year warranty on parts, will probably charge you a flat labor fee plus shipping. If you do not have your purchase documentation for warranty, dump it and replace. If you can, then you may wish to have it repaired.
My customer replaced theirs; I am trying to purchase replacement parts to repair...good luck.
Posted on Feb 25, 2009
Buddy Mcsparrin
  • 1684 Answers
SOURCE: Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Posted on Jul 24, 2009
Pictures not showing.
make sure the cards' slide button is in the unlock position..then check to see which size cards the frame can work with..mb sizes like 2/4/6/8/12 etc..
Jan 11, 2014 | Audiovox DPF700 Digital Picture Frame
I have a black square on which my twitter profile information sits - how do I change the black background to something else?
If you want to upload your own background image or customize the sidebar and color scheme of your page, follow the steps below.
  1. Sign in to your account.
  2. Go to your Settings and click on the Design tab.
  3. Scroll down to the Customize your own section.
  4. Click on Choose file to upload a background image. images justify to the top left of the screen. You cannot stretch your image to fit. It will display as the size you uploaded (file must be smaller than 2MB).
  5. Check the box to Tile background if you want your picture to repeat across the background.
  6. Choose whether your Background position will be left, center or right.
  7. If your image isn't very large, choose the background color that will show behind the image.
  8. Choose a color for links.
  9. Choose a black or white transparent overlay.
  10. Click Save changes.
Source: Customizing your profile design
Jan 09, 2014 | Computers & Internet
How do you set the background on a Dell to show a slideshow of all of the pictures?
To use your own pictures
1.
Find the pictures that you want to include in your slide show. All of the pictures must be located in the same folder.
Open Desktop Background by clicking the Start button Picture of the Start button and clicking Control Panel. In the search box, type desktop background, and then click Change desktop background.
2.
If the pictures that you want to use aren't in the list of desktop background pictures, click the Picture location list to view other categories, or click Browse to search your computer for the folder where the pictures are located.
Picture of the Picture location menuLook for pictures in other locations on your computer.
3.
Select the check box for each picture that you want to include in your slide show.
By default, all of the pictures in a folder are selected and will be part of the slide show. If you don't want all of the pictures in the folder to be included, do one of the following:
Clear the check box for each picture that you want to remove from the slide show.
Picture of one check box cleared in a group of selected photosClear the check box to remove a picture from the slide show.
Press the Ctrl key, and then click each picture that you want to remove. Only the selected pictures will appear in the slide show.
To create a slide show of pictures on the desktop, you must select more than one picture. If only one picture is selected, the slide show ends and the selected picture becomes the desktop background.
If all of the pictures in the folder are selected, any new pictures that you add to the folder will be added to the slide show automatically.
4.
Do one or more of the following:
Click an item in the Picture position list to crop the pictures to fill the screen, fit the pictures to the screen, stretch the pictures to fit the screen, tile the pictures, or center the pictures on the screen.
Click an item in the Change picture every list to choose how quickly the slide show changes pictures.
Select the Shuffle check box to have the pictures appear in a random order.
5.
Click Save changes.
To use pictures that Windows provides as part of a theme
1.
Open Personalization by clicking the Start button Picture of the Start button, and then clicking Control Panel. In the search box, type personalization, and then click Personalization.
2.
Under Aero Themes, click a theme to apply it to the desktop. With the exception of the Windows 7 theme, all of the Aero themes include a desktop background slide show.
3.
To change the theme's default slide show pictures or settings, click Desktop Background.
4.
By default, all of the pictures associated with a theme are selected and will be part of the slide show. To add pictures from other themes to your slide show, do one of the following:
Point to each picture that you want to add to the slide show, and then select its check box.
Picture of one check box cleared in a group of selected photosPoint to a picture, and then select its check box to add it to the slide show.
Press and hold the Ctrl key, and then click each of the pictures that you want to add. Only the selected pictures will appear in the slide show.
5.
To change the slide show's settings, do one or more of the following:
6.
Click Save changes.
Your slide show will be part of the unsaved theme that appears under My Themes.
For information about customizing and saving themes, see Create a theme.
You can find more themes to add to your collection in the Personalization Gallery on the Windows website.
For information about customizing a desktop background slide show, see Make changes to your desktop background slide show.
Aug 04, 2011 | Computers & Internet
How do i set laptop background image on my compaq 615?
This can be found in the Help and Support section of Windows on your laptop.
To change the desktop background
  1. ?id=microsoft.windows.resources.shellexecutetopiciconRight click on your desktop-Select personalize. This will open a window that asks you to select your desktop background
  2. Click the picture or color that you want to use for your desktop background.
    If the picture you want to use isn't in the list of desktop background pictures, click an item in the Picture location list to see other categories, or click Browse to search for the picture on your computer. When you find the picture that you want, double-click it. It will become your desktop background.
    getcontent.aspx?assetid=8456a207-d4c8-401d-8729-c5dda3f0e72c&documentset=en-us&prod=win700&market=usLook for pictures in other locations on your computer
  3. Under Picture position, click the arrow and choose whether to crop the picture to fill the screen, fit the picture to the screen, stretch the picture to fit the screen, tile the picture, or center the picture on the screen, and then click Save changes.
Note
  • If you choose to have a fitted or centered picture as your desktop background, you can also frame your picture with a color background. Under Picture position, click Fit or Center. Click Change background color, click a color, and then click OK.
Tip
  • To make any picture stored on your computer (or a picture you are currently viewing) your desktop background, right-click the picture, and then click Set as Desktop Background.
getcontent.aspx?assetid=7abb27d7-2989-4144-81e3-0a51f703885d&documentset=en-us&prod=win700&market=usThe Set as Desktop Background option
Apr 24, 2011 | Computers & Internet
I want to change my desktop background.
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
Jan 30, 2011 | Computers & Internet
How do i set a photo as desktop background? cannot find desktop properties...
  1. You can right click on the picture itself and select "set as Desktop background"
  2. Or:
  3. Click on the Start menu button. Then click on Settings and then on Control Panel.
  4. Double-click on the Display icon or text link. This will open a window named Display Properties.
  5. Click on Background if that tab is not selected. Click on one of the items that appear in the box labeled Wallpaper.
  6. Inspect the preview that appears above the Wallpaper menubox. Use the Display menu to the right to experiment with tiling, stretching or centering the picture that you are previewing.
  7. Click on Browse to use an image stored elsewhere on your hard drive. Locate the image and click Open.
  8. Click OK to change your background, or wallpaper. Click Cancel if you decide to maintain your current settings.
Read more: How to Change the Background Picture on the Desktop ' eHow.com http://www.ehow.com/how_5177_change-background-picture.html#ixzz1CRtCnmqv
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 29, 2011 | Samsung N150 (36725723009) Netbook
The LCD screen on my 40D shows the image taken, or the live view image, but there are large areas of missing image. Almost like the picture has been laid on a black background then a large piece torn out...
If the Live View shows areas of total black, the LCD is probably faulty and needs to be taken to a Canon Dealer for repair/replacement. I believe the pictures are still okay on the computer in this case?
Mar 25, 2010 | Canon EOS 40D Digital Camera
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Two problems vx922 Black screen of Death and vx910 no power
You may want to tey another computer or another cable or update your video card drivers. Otherwise look very closely and see if you are able to see a very faint image of your background picture or icons if you have any.
Really im not kidding it might be a backlight issue.
Nov 18, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Display images missing on MP3, background black!
You can set one of your own pictures as the background by viewing it and holding down the center touch pad button. The bottom of the screen will say Set Wallpaper and you can let go of the button. now that picture will be set as your background image
Jan 16, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Computers & Internet Logo
716 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
