The fridge side seems to not be working now. Please Help
Before going to buy any parts
directly. This is list of refrigerator problems,
which is normally faced in refrigerator. -------------- ------------ ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html These will help. Thanks,.
Go through this troubleshooting help links.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making
ice?
Water Overflows in Ice maker
and freezes inside?
How to replace Ice maker
assembly?
SOURCE: Buzzing sound
the buzzing sound is the compressor trying to start. Unfortunately, it is locked up and the overload is cutting it out. It resets every couple of minutes or so. The problem is the compressor. You can try a hard start capacitor to see if it breaks loose, this is the cheap fix, otherwise it needs a new compressor, the expensive one.
SOURCE: Amana bottom frezzer refrigerator
Gazzo, You are on the right track. I've been finding a lot of compressor failures on these Amana's. It's possible that the overload and relay for the compressor failed, but Im more inclined, from what I've seen, that the compressor is the problem. The compressor is covered under warranty, parts and labor for 5 years. I would call for warranty service...Catriver...post back.
SOURCE: Side by Side Frigidaire Galleria
clean the heck out of the coils underneath and give the manufacture a call, you should be covered by a 5 yr warr on your compressor(reason i say clean it is if they come see it clogged they'll blame you and deny your warr.stating cust abuse
SOURCE: frigidaire gallery model plhs267Za
It sure sounds like a compressor problem to me. The buzzing sound is the compressor trying to start followed by a click which would be the overload protector tripping.
SOURCE: freezer fine /After power went out twice fridge not cold enough
In back of the refrigerator is a removable panel behind which is the compressor. Listen for a hum and a click. If you hear those sounds the compressor may have failed. Behind that same panel is a condenser where heat is removed from the refrigerating system. Make sure it is clean and check that the fan operates when the compressor runs.
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
