Question about Fisher 9925 Shelf System
M-error message on Fisher studio 24 tad-9715 how do you reset or fix this so it will play cd's again
Ron Oblinsky
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
TAKE COVER OFF THERE IS A MEMORY RESET BUTTON ON THE LEFT SIDE ON LOWER BOARD
Posted on Apr 19, 2014
4 Related Answers
Anonymous
SOURCE: I HAVE A FISHER TAD-9415 SYSTEM AND THE CD WONT
hope it is not too late but have had the same problem, just got around to open up the case and found the problem and was able to fix mine and now it plays fine. My problem was with the cd turn table it was not be feeding the cd into the player causing the m-error..
Posted on Dec 11, 2010
supertech6
John Street
  • 513 Answers
SOURCE: THERE IS NO audio frm my fisher tad-9925.....the
Its a little hard to diagnose over the computer.
I assume there is no sound from the amp EVER.
I assume you have tried other sources.
I assume the unit worked OK until the IC blew.
I assume you replaced the IC yourself?
Often, parts with the IC also fail. There maybe fuses that look just like little resistors along with the IC. They might be blown.
There are parts in the circuit to test if there are speaker problems called power resistors. These will frequently open circuit when the IC Blows - you won't be able to see anything visually.
If your stereo normally makes a 'Click' sound just before the sound comes on, and now there is no click, this indicates the repair of the IC is not complete yet - find the blown part.
Posted on Mar 22, 2010
Anonymous
SOURCE: disc will not eject nor play on fisher studio 24 management syste
remove the screws to your cd player and take this apart and remove the disk by hand and put system back together. It should work after that. I am a former tv technician. just be careful how you take it apart to put it back together again. do not plug unit in untill it's all done to avoid eye damage from the UV rays.
Posted on Mar 04, 2009
Anonymous
SOURCE: fisher tad 5060
the only way to reset a error disc is to unplug the radeo and push air dust the cd mech and lens then push the lens all the way back plug the power cord the, turn on power it should reset itself , i had same problem before and it work.
Posted on Jul 21, 2010
Only 9 0f 24 slots play on my Studio 24 CD Management System
I'd say you have a bad belt or maybe it needs a thorough cleaning. Most likely the belt(s)
Apr 21, 2014 | Fisher Studio Standard
Manual for TAD-9715 Fisher
did you try a lot of cds? i mean more than 1 cds? coz if you already try it.. maybe some part of the cds.. has damaged. or the lens.. or maybe it was disalligned..the slider of that cd...all you have to do..open your cd player..!! try to look the lens area.. you can use cotton..clean it with a cotton.. only the lens.. and try to touch the slider.. i mean.. move it.. but not so hard..
you have that warranty? call your dealer instead before making moves to apply the warranty of it,,,
Aug 06, 2012 | Washing Machines
Fuzzy sound
Hi. Try moving it to a different room. If you have florescent lighting or too close to a fan or running electric motor. Check for bad ground on unit.
Make sure speakers are connected properly. + to + - to - left to left and right to right. Hope that helps.
Mar 09, 2012 | Audio Players & Recorders
Dec 07, 2009 | Fisher 9925 Shelf System
Fisher Model TAD-993
On my Fisher model TAD-993, when I press load/eject button the screen reads m-error, do you know how to cure this
Oct 05, 2008 | Audio Players & Recorders
Cd player
i need part # 6142539071 for fisher tad 993
Jul 09, 2008 | Audio Players & Recorders
Fisher TAD-5024
YEP IT IS ******** AND I WASTED MY MONEY ON IT
Mar 15, 2008 | Audio Players & Recorders
Fisher tad 5060
Nov 09, 2007 | Fisher Audio Players & Recorders
Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Mar 19, 2007 | Fisher 9925 Shelf System
Fisher 9925 Shelf System Logo
Top Fisher Audio Players & Recorders Experts
ray gallant
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
