RCA P52960 52" Rear Projection Television Logo
Question about RCA P52960 52" Rear Projection Television
I was given a P52960 ,2002 rca 52 projection tv and the sides of the piture are concaved in.Can this be fixed easy enough,i am good with electronics/wireing..iI was told by the old owner that the solu
I think i described everything pretty good
Posted by ronbodelmer on
Anonymous
    New Friend:
  • 13 Answers
Concave or bloated pictures on crt projection tv's are corrected with what's called a 'pincushion' adjustment. Look for it in the menu under video controls.
Posted on Dec 22, 2012
5 Related Answers
Anonymous
  • 1030 Answers
SOURCE: My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Posted on Dec 21, 2007
Anonymous
  • 1030 Answers
SOURCE: OWNERS MANUAL FOR RCA
owners manuals or user guides are availble online at rca.com
Posted on Jan 18, 2008
Anonymous
  • 77 Answers
SOURCE: rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Posted on Oct 21, 2008
Anonymous
SOURCE: 52" rca rear projection
the picture is bent inward and shadow looking sides are cut off.
Posted on Sep 06, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: I have an RCA 52
Replace the deflection board. You can get a replacement board from www.tvrepairworld.com which also contains the Cd with installation instructions.
Posted on Jan 13, 2010
6helpful
The picture has a triple image
Very common and easy fix. Install the RCA repair kit called ' ITC222 and ITC222A convergence option missing repair kit. Its available from www.tvrepairworld.com and contains the parts and the CD with repair instructions.
I have an RCA 52" projection Tv, After it has been on for about 30-40 Mins the picture Goes concave.
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Rca picture concave 52 in rear projection
Concave screen blurred picture
Good Day, trinityfaith;;
The RCA is very different then most TV's. It could be one of four boards that's causing this. There is no common one. Please call a Factory Service Center and have give you an estimateb4 repair. Sorry, but Good Luck, big IRISH. PS You are looking at a 4 to $550.00 repair.
TV all blured and screen concaved on all sides
Look,followsteps and you wil repair this set. Disconnect main board ( fly back), take care about connectors. Under fly back you will see loose connections, resolder and that's it Am sure this is your solutions.You need do this soon, because fuse will be blown if keep blink picture, Thank you
RCA P52937SG
ch over the power supply for the conv this is the stk730-020 that run your conv
1helpful
52 rca concave pic and bad colors
concave and colors off indicate the convergence cuircit is bad. which can be one of three boards. sorry
Open Questions:
See all RCA P52960 52" Rear Projection Television Questions
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
