Question about Samson C01U Consumer Microphone
I'm trying to install a C01U microphone into my macbook air
My macbook air doesn't have a cd drive only a usb is there another way of installing the program?
Posted by brenda martinez on
Adam Vasquez
    New Friend:
  • 3 Answers
1. Does one of your friends or family have a computer with a cd drive? And a USB jump drive? Have them move the files from the cd to the USB stick and insert the USB stick into the computer and install from there.
2. Buy an external cd drive from Best Buy or Frys.
Posted on Dec 22, 2012
5 Related Answers
Anonymous
SOURCE: tips on Using the Samson C01U with Cakewalk Pro Audio 9
Try this:
Control Panel > Sound Audio Device > go to Voice Tab > check your drop down list for Voice Recording and make sure you put on Samson C01U then test your hardware and see you get any pick up. I had to research on what to do.
Now my problem is why the mic is only picking up on the left side of the ear instead of the right. =/
Posted on Jan 08, 2009
PBandJ
PBandJ
  • 29 Answers
SOURCE: C01u PROBLEM PLS HELP ?!
That's the way it's supposed to work. It's a mono microphone, so there's only one signal to record.
Set up your recording software so that it only records the Left channel. It describes how to do this on the Samson FAQ page and in the Owner's Manual:
"In your digital audio workstation (DAW), create a mono audio track, and set it to the Left channel of the C01U (the Right channel should be ignored). Arm the track for recording, and adjust the input gain by using the software control in your computer's operating system"
Don't try to alter the pan so both sides are the same; that will just screw up the levels and noise.
Posted on Mar 01, 2009
Fred Yearian
  • 5603 Answers
SOURCE: whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Posted on Sep 30, 2009
Anonymous
  • 17 Answers
SOURCE: I use the samson C01U
1. Try reinstalling the softpre software.
2. Read through their FAQ at: http://samsontech.com/products/productFAQs.cfm?prodID=1810&brandID=2
3. Contact samson directly at [email protected] with your problem.
Posted on Mar 08, 2011
jeremy guerra
SOURCE: When I started my computer
you more than likely have your settings messed up follow this video it should fix the problem
Posted on Jul 25, 2011
My macbook air disk drive doesn't take any cds in
Thanks for asking your question with Fixya Support. I will be glad to assist you.
For simple but in-depth troubleshooting, I suggest this link for you to review in regards to working toward resolving the Macbook Air SuperDrive CD /DVD issues.
If the guide provided above does not resolve the problem, then the issue here is that your USB Superdrive (unless you are using a different non-Apple 3rd party CD/DVD drive) is experiencing a mechanical failure.
This Apple external USB CD/DVD SuperDrive is fairly straight-forward in its use.
Now if the issue you were having had something to do with only a DVD or CD constantly ejecting automatically after you placed such a disk in the drive, that would be different.
In this case however, if the guide above does not help and you are experiencing the SuperDrive working intermittently, my advice, is to take your Macbook Air with the external SuperDrive in to your local Apple retail store Genius bar or Apple Authorized service provider for a free diagnostics to determine the root cause of the SuperDrive failing intermittently.
Feel free to reply back if you have any questions regarding the information I have provided you.
Regards,
- MacTechTrainer
Jun 05, 2012 | Apple MacBook Air
Hello, I just purchased the C01U USB mic and whenever I test or record with it I get this really high pitched noise. but when I tap the Mic is goes away and then slowly fads back in after a couple of...
1. Try the microphone on another USB port and check.
2. If not OK, try the microphone on another computer and check.
3. If OK on another computer, re-install it or recover the O.S. from a backup.
4. If on another computer the same problem exists, the microphone could have a internal control defect.
Aug 20, 2011 | Samson C01U - USB Studio Condenser...
My Samson C01U microphone doesnt seem to be working. the green light doesnt turn on when i plug it into the usb port of my computer. I have windows vista. Is it not compatible?? The computer says the...
Sorry this isn't a solution but just letting you know I'm having the same trouble, the funny thing is mine was working a couple of months back and now its not, it's driving me crazy.
May 19, 2011 | Samson C01U Consumer Microphone
I use the samson C01U usb microphone on my macbook pro for almost 4 years. Now I recently updated to mac os 10.6.6 (latest update) and Samson soft pre won't start up anymore. I can't configure the mic...
Mar 03, 2011 | Samson C01U - USB Studio Condenser...
Whistling background noise with Samson C01U USB condenser mic
Sep 28, 2009 | Samson C01U - USB Studio Condenser...
Jan 08, 2009 | Samson C01U - USB Studio Condenser...
Stereo Playback
did you download the samson pre amp app
Aug 03, 2008 | Samson C01U - USB Studio Condenser...
Samson C01U Consumer Microphone Logo
135 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
