Nikon DSLR D90   Digital Camera Logo
Zafar Qureshi Posted on Dec 22, 2012
Memory Card Indicator always blinks - Nikon DSLR D90 Digital Camera
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
696
Points
Since a couple of months, my "out of warranty" D90 is having a problem.
Even after shutting down the unit , sometimes (post of the time) the green led is blinking (at random speed) untill the battery is 100% down (after half a day).
Switching memory card , or formatting memory card does not help.
Even without lens , problem occurs.
I tried also a other battery pack , same problem...
Anyone has an possible reason why this happens , or a 100% working solution.
PS: D90, battery packs and charger are 100% genuine NIKON.
Regards, Rik
System cannot find file specified
your memory card has bad sectors that needs fixing by typing chkdsk x: /f /r (where x is the memory card) at the command prompt on your pc/laptop
2answers
Hi good morning, my hp 6735s doesnt display anything when I power it on. it flashes a quick brief light on the screen and keep blinking an orange light thereafter the caplock (blue) light comes on and...
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the back up( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. If not the OS is a suspect.
It is also possible that the mother board is faulty but can be confirmed only after you ensure that the memory and power supply is good.
Thank You for using Fixya
Why is the media card reader and access indicator light always on? I have never inserted anything into it.
This may be it's normal mode to indicate it has power available.. After media is inserted it may change color to green and blink or remin the same color and blink as it accesses the media.
1helpful
Blank screen when the unit is switch on
Chances are, the unit is bricked. A firmware issue. Try doing a reset.
Also, this could manifest a problem with the memory card. It could be that it is unable to read it. Can you see the memory card indicator blinking? Try to use a different card to troubleshoot the problem.
When the computer is turned on via the power button, the computer does not come on. When I check the LED indicators, the on/off indicator goes green, the battery power indicator is first orange, then...
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Blank screen
Genius G-Shot HD55 (camera) - How to get SD card working??
For Genius G-Shot HD55 you need to insert the SDHC card deeper into the slot until it clicks closed, like opening a pen, then when you want to remove it press it again until it clicks to release, like closing a pen. Your card is recognised after the deep click insertion and restarting the camera.
W700i Screen and Keypad blinks....
SS - you should try and have the mobile check to make sure that the memory card is working properly.
GUEST - the firmware need to be reflash so take the phone and have it done.
Blinking red indicator light
Hey pollyannac,
The red blinking light probably means either the flash is recharging, or the camera buffer is full and it is writing files to your memory card which the lcd monitor should read Busy while the camera is writing the files. If it is the flash recharging then you could try using more powerful batteries such as the Canon NiMH AA batteries. If the problem ends up being the camera is writing images to the memory card you could try getting a memory card that has a high write speed. These memory card are usually more expensive, but in my opinion well worth it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Screen suddenly goes blank
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
