Question about E-Machines eMachines Desktop PC
Need wiringdiagram for an ET1161-05 with motherboard
I took off the cover to clean it out and when i hooked it back up i couldnt even get it to boot in safe mode and its telling me theres no drivers for it. I have an e-machines ET1161-05 with vista, but I installed windows 7 about a yr ago. I didnt take anything out or unplug anytthing on the inside but Im wondering if I knocked something out of whack or something.
Posted by Karen Marmon on
joecoolvette
  • E-Machines Master
  • 5,660 Answers
1) Did you unplug it from power?
2) Did you FOLLOW Anti-Static Precautions?
Anti-Static Precautions;
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer ON a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
3) A small primer if I may;
You press the Power On Button. The Power On Button is a plastic assembly, that has the Power On switch inside it.
The Power On Button presses the Power On switch.
Pressing the Power On switch BRIEFLY closes a circuit.
The Soft Power On circuit.
(The Power On switch is a Momentary Contact Switch)
{When the Power Supply, (Computer), is plugged into power, there is a constant 5 Volts present. (DC) The 5 Volt Standby power.
This is used for the Soft Power On circuit }
Briefly closing the Soft Power On circuit, 'excites' the Power Supply, and turns it on. (Almost sounds wrong in so many levels)
The first chipset (I.C.) to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized. (BIOS)
BIOS looks to see what DEVICES are installed, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System. (In this case Windows is the O/S)
Driver: A small piece of software that allows the Operating System to communicate with a DEVICE.
My thinking is the Device is the Harddrive.
Either the Power Supply, power cable is unplugged a little bit; and/or the data cable.
The eMachines ET1161-05 uses a SATA harddrive.
Serial ATA
Means it also uses a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note that between a SATA power cable's connector, and a SATA data cable's connector; the SATA power cable connector is Longer.
The SATA power cable connector has 15 contact pins.
The SATA data cable has 7-pins,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
The SATA data cable connector that plugs into the SATA harddrive, is usually a 90 degree bent elbow connector.
The straight connector end plugs into the motherboard.
(Also note the L-shaped opening, in the SATA data cable connector, shown. The SATA power cable connector also has this L-shaped opening. Mates to the L-shaped connector on the motherboard, or harddrive; or SATA optical drive )
Just physically see if you can plug these connectors in tighter, on the harddrive. (Remember; Power unplugged; follow Anti-Static Precautions)
Also remove all Ram Memory modules. ('Stick')
Now reinstall them.
You may have one that is loose in it's ram memory slot.
Visually inspecting will NOT do. To be assured the Ram Memory module is seated tight in the ram memory slot, you have to remove, and reinstall.
Post back in a Comment.
Regards,
joecoolvette
Posted on Dec 22, 2012
5 Related Answers
Anonymous
  • 452 Answers
SOURCE: bios problem
cnge BIOS cell & then try .
Posted on Oct 13, 2007
Anonymous
  • 111 Answers
SOURCE: emachine t3112 only work in safe mode
you need to run the new hardware wizard as there are differnet drivers needed for the mb
Posted on Dec 19, 2008
dennis bullard
  • 4090 Answers
SOURCE: MY T5088 E-MACHINE CAME WITH VISTA. I WANT TO
If you have Windows Vista Home Basic Then any attempt to install XP will be disasterous! You can thank Microsoft for this bit of chicanery.They want you to stay with Vista and so the boards fitted do not accept XP drivers
Please rate my help++++Thanks for usingt FIXYA
Posted on Feb 26, 2010
Testimonial: "DOESN'T SOUND FAIR. "
Anonymous
  • 174 Answers
SOURCE: Microsoft Teredo Tunneling Adapter
http://en.wikipedia.org/wiki/Teredo_tunneling
You don't really need it and can remove it unless you are using IPv6 which no one really is at this point.
Posted on Mar 18, 2010
Anonymous
  • 95 Answers
SOURCE: My E-Machines T5088 PC Desktop boots fine in
Run start up repair.Alot of times vista can repair itself with this function
Posted on Mar 31, 2010
Took apart my FIC AM 37 motherboard i (think) i got everything hooked back up correctly. i turn the power on and it boots up but i dont get no connection to my screen. any suggestions?
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Jun 16, 2011 | FIC AM 37 Motherboard
I took out the bobbin case and then the shuttle race. Now I can't remember which one I should put back in first.
Clean the shuttle area, the hook and the cover with a toothbrush, removing all lint and debris. Place one small drop of sewing machine oil on the rim of the hook. Place the hook back in the raceway and replace the cover. Snap the two retaining levers back to hold the cover in place.
Jun 02, 2011 | White Sewing Sewing Machines
My Xbox360 has 1 red light blinking and I am getting a e74 error. Since it is out of warranty, I decided remove the x-clamps, clean the chips, put on some artic silver 5, and see if it would do the trick....
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console.
click here to download repair guide
Dec 14, 2010 | Microsoft Xbox 360 Console
I have a ABIT-V17 Motherboard with intel pentium 4 CPU and 1GB\RAM.. and Windows 7 Ultimate OS... I was doing a system cleaning when I removed the power cord and turned off the power I started taking my...
U indicated that you were able to get into the bios. Strange that all you did was dis assembly the PC, put it back together the same way, and now it does not work. Assuming you put everything back the exact same way it should work. Make sure that all of your connections are good and tight. Also check to see if the PS is working or connected properly. Try disconnecting all components except the memory and monitor and boot. If it works to a screen turn it off and start hooking up other peripherals one by one till you get no video or it stops working.
A bad peripheral can often disrupt a normal boot up process and cause all sorts of mayhem.. Check them all out.
And make SURE that your memory chips are in there properly!!!!!!!!!!!!!!!!!!!!
Mar 03, 2017 | Abit VI7 Motherboard
Acer t135 pc desktop will not get to bios page or startup at all
1 Did you unplug the PC prior to opening it, and turn off the switch on the back?
2 Did you wear a wrist strap or ground yourself to bare metal on the case before you touched it each time?
3 Did you remove the motherboard from the case or work with it inside?
4 Did you put new thermal paste on the bottom of the processor before hooking it back up?
5 Did you make sure the heat sink is firmly fastened to the processor prior to turning it on?
6 Did you remember to plug in the processor fan to the motherboard?
7 Did you make sure all lines and cables from the hard drive and CD/DVD are firmly plugged in to the motherboard prior to booting?
I see where the hard drive boots up. But is the cable hooked up properly too?
What kind of processor, motherboard, and operating system do you have?
Numbers 4,5,and6 are pretty much fatal if not done or done properly. It only takes turning on a CPU once with no fan or properly installed heatsink to fry it.
If you've done all this, please forgive the questions, but you didn't say and I don't know what your level of experience in working on computers is.
If any of those items are not done, you need to do them. If you need directions write back.
Once done, then you need to clear the CMOS by moving the jumper on the RTC for say a half minute, then putting it back. Are you familiar with that? There are 3 pins, and the jumper will be on 2 of them. Move it the the uncovered one and the one adjacent to it. After 30 seconds or so, put it back on.
After that, there are a few differences of opinion on how to proceed. But I would put everything back except the side cover. Plug it in. Turn on the switch in the back. After a few seconds you should see a light on the back side or thereabouts come on. This tells you the motherboard is powered.
Turn the computer on, tapping F3 constantly with your finger to enter set up. Clearing the CMOS wipes out all your preferences. If you are lucky, and it boots you into set up, look at the top where it says "load Default settings". Press that and the save your changes and exit.
If the Gods are with you it will boot on in to Windows, if that is what you are using.
BUT. You must clean off the old thermal paste from the bottom of both the cpu and the heat sink. You can use rubbing alcohol and cotton (my ears are burning already). Apply a new thin layer with like a busness card, so it is evenly spread and very thin. Be careful when placing the heatsink back on it. Hook the back side first and then (I use needle nose pliars or a dull wooden pencil) push the other side down until it is hooked well onto the platform.
If this doesn't work, or you need help, please write back.
Sirwriter
May 14, 2009 | Acer Aspire T135 PC Desktop
SYSTEM DOESN'T BOOT UP, GET LONG STEADY TONE WHEN SYSTEM STARTS
please check the system memory (RAM)
remove them and carefully clean in mouth with a clean A4 white sheet
or change the memory if possible...... and if problem still occur, please check the system processor too...
to check if the processor is functioning, remove the heat sink on the processor and boot the machine placing your finger on the processor chip.
it burns your finger after a short sec. BUT this should be done in a controlled way and after the memory had been tested for
May 10, 2009 | ASUS P4S533-MX Motherboard
Replaced the clutch in my xlh1200 1995 with a kevlar clutch kit. when I put it back together I couldnt squeeze the clutch. I took off the derby cover and figured out that the adjustment screw was hitt
I would go back to scratch. Disassemble the clutch basket and reassemble it making sure you have it set in proper order. Then reassemble every thing. Also double check the clutches you bought are the proper ones for your bike.
Apr 25, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Model 8280. The thread on the bottom keeps bunching up. It is a horrible mass of thread. Then, it stops moving. Can you help me?
I had the same problem and I tried everything including removing the bobin case, cleaning out lint, changing the needle, adjusting the tension but it did not work. Then I finally tried reloading the bobin thread, making sure to load the bobin according the manual directions....and the problem was solved...no more tangles... just a nice even stitch...yeah!
Jan 04, 2009 | Singer 8280 Mechanical Sewing Machine
Computer will not boot
Did you put a CPU in it? That's the only thing you didn't talk about in your post. Other than that, are mem modules good?
Geno
Mar 10, 2008 | Computers & Internet
No laptop screen.
this might be your conector from the screen to motherboard.if you carefully press down on the key board in the area around f6 keys -f11 keys and number 6 key to + keys.it may be enough to get the screen connctor down.But be careful.If you are brave enough you may lift bezzle and remove keyboard and de-tatch the screen connector c;ean motherboard connector and re-atatch carefully
Aug 10, 2007 | Dell Inspiron 710m Notebook
E-Machines eMachines Desktop PC Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
