Error code 6000 displayed
SOURCE: 6000 error on a Kyocera
a fuse it is blown within the FUSER UNIT - replace that fuse or call a technician to do it for you.
SOURCE: CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
SOURCE: Error code 6000:0106504
Fuser problem, you shall change fures termistor or lamp or both..Good Luck
SOURCE: I have a kyocera FS-2000D with error code: Call fo...
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
SOURCE: how can I resolve kyocera
Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Follow the flow chart:
Turn power switch off, and
remove power cord.
Detach YC7 connector on
the engine/high voltage
PWB.
Measure resistance
between pins 1 and 2 of
the detached connector.
Open
(infinite)?
Yes ---> Replace the fuser thermistor.
NO ----> Detach YC1 connector on the power source PWB.
Measure resistance
Open
(infinite)?
Yes ---> Replace the thermal cutout or heater lamp.
NO ----> Replace the engine/high voltage PWB.
6000 error is a fuser error. Check connections; make sure the back door/cover where the fuser is located is closed. Turn the machine off, unplug, plug back in, and turn printer back in; if you are still getting the error the fuser will need to be replaced.
