There is a small spring included in the package but my old stem did not have a spring. Do i need the spring and if so how and where do i install it.
SOURCE: how to insert a hot cold ste, 3Z-6H/C FAUCET
#1 THE FAT PART OF YOUR SPRING GOES INSIDE THE FAUCET ,AND SIT ON THE VALVE BODY(SEAT)
#2 THE LITTLE BLACK WASHER SIT ON TOP OF YOUR SPRING
#3 PUSH THE STEMS IN THE CORRECT SIDES HOT ON LEFT.CAUTION THERE IS USUALLY NOTCHES ON THE SIDES OF THE STEMS TO HELP YOU ALIGN THEM IN THE VALVE BODY,
4 PUT THE NUT BACK ON ,TIGHEN SLIGHTLY,TURN ON THE WATER TO CHECK ,IF OK RE INSTALL YOUE HANDLES
SOURCE: How do the 3 pieces
first off, put the spring in the faucet big end down. then put the black rubber boot seal in next and push it into place. Then place the Stem in but be sure to line up the notches before you screw it all down. I hope the will help you....
