Question about Fossil JR Watches
Need to set time on fossil watch JR8864
Need instructions
4 Related Answers
diarmaidok
  • 4 Answers
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Posted on Dec 02, 2008
Anonymous
SOURCE: Instruction Manual for Fossil Watch
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
Posted on Feb 21, 2009
Anonymous
  • 8 Answers
SOURCE: Question:how to set the weekday on a Fossil watch model BQ-9165.
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
Posted on Mar 03, 2009
Anonymous
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
Posted on Apr 04, 2009
I need to set time on a fossil fs4829
Google (fossil)(FS4829)(manual) without parens for instructions.
Feb 17, 2014 | Fossil FS Watches
I need an instruction manual for a fossil fs2919 watch to set the dials
Follow this link and download manual for your watch:
http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10
Oct 01, 2010 | Fossil FS2919 Wrist Watch
My chronograph men's watch came without a manual. Where do I find a manual that discusses setting time, cleaning the watch, setting teh date, etc?
Philleo Stark are made by Fossil.<br /> <br /> Go to <a href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</a> and you will see "watch instructions", ckick on this for download of the instructions. They are generic instructions, so you need to scroll down to find the one that looks like yours and download the file.
Aug 26, 2010 | Fossil Philippe Starck PH1035 Wrist Watch
No Manual. How do I set the time and other functions?
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html and you will find a list of generic instructions in which you should be able to find a set that suit your watch.
May 04, 2010 | Fossil Philippe Starck PH1035 Wrist Watch
NEED TO RESET THE TIME, NOT SURE HOW TO DO THIS
Go to www.fossil.com and go to customer care. Once there go to watch manuals and look for your watch.
Apr 06, 2009 | Fossil AU4003 Wristwatch
Fossil Watch Chronograph Problem minute counter resets to 59 instead of 60
1. Pull out the time set mode button.
2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60.
3. Press the time set button back into normal position.
Oct 01, 2008 | Watches
Watches Logo
116 people viewed this question
Top Fossil Watches Experts
Janelle Schoonover
Janelle Schoonover
john h
Ngoro
Are you a Fossil Watch Expert? Answer questions, earn points and help others
