Have a qualified repair shop check it out . Electronic module involved , WCM - wiper control module . May have code's stored . You have no clue as to how it works.
The windshield wipers are controlled by the wiper control module and the driver-operated multi-function switch on the steering column, with the ignition switch in RUN or ACC position.
There are four modes of wiper operation: OFF position, the wipers move to and stay in the park position; Interval position, the wiper control module causes the wipers to cycle, separated by pauses, pause time length being determined by switch location; LO position, the wipers will operate at low speed continuously; HI position, the wipers will operate at high speed continuously.
The windshield washers are controlled by pressing inward on the wiper switch end of the multi-function switch. The washers will operate as long as the switch is depressed. If the wipers are in the OFF or Interval operating mode, the wipers will begin in LO speed and the washer pump will pump fluid from the reservoir to the nozzles. When the switch is released, the wipers will complete three cycles and then return to their previous setting. In LO or HI mode, no change in wiper operation will occur during washer operation.
The washer fluid level sensor is in the windshield washer reservoir (17618) and is monitored by the hybrid electronic instrument cluster (HEC) and displays a WASHER message when the fluid level is low. The washer fluid level sensor and windshield washer reservoir are replaced as an assembly.
- The Low Wiper Speed Does Not Operate Properly
- Multi-function switch.
- Wiper motor.
- Circuitry.
- Wiper control module.
- The High Wiper Speed Does Not Operate Properly
- Wiper motor.
- Circuitry.
