SOURCE: Asko W640 water outlet fault
If you get the water fault after checking the lower drain, you may need to remove the drain hose in the back. Usually there is a dime in the hose or the hard part right before the hose.
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
SOURCE: Wash temperature scale
TEMPERATURE - CELSIUS OR FARENHEIT
If you want to change the temperature indication from Celsius (C) to Farenheit (F), proceed as follows:
Turn the main switch, off and turn it on again. Press the Enter button five times, then press the P2 button five times. These ten times must be completed within fifteen seconds. Within three seconds after pressing P2 the last time, use the < > buttons to select temperature indication.
SOURCE: asko w6441 housekeeper pushed buttons too
Hello John, Welcome to FixYa. I can provide you with an Asko service manual that should guide you on how to remove the panel and anything else you may like to do as well. The service guide I have is an Asko W600 series ( that includes yours ) from Asko in "pdf" so I could attach it to the email address you provide if you give the go ahead. I'll watch for your reply. Regards, Macmarkus :)
