Drum roll............................and the unit is?
Need laptop manufacturer and model number. Model number can be found on the bottom of the laptop.
In the meantime; with the laptop off remove the AC adapter (Charger), and Battery.
Press the Power On Button in, and hold for a count of 10 seconds.
(And I mean 10)
Let go of the Power On Button. Do this procedure two more times.
Now reinstall the Battery, plug the AC adapter back into laptop;
THEN into power.
WAIT 1 minute, turn the laptop on.
Post back in a Comment.
Regards,
joecoolvette
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
