Question about Elna Sewing Machines
How do I remove the cam from an Elna Air Electronic SU?
The machine is working, but we have no manual. I can't find any way to remove it, and we have 17 other cams to try. The cam has probably been on the machine for twenty years or more. Perhaps it is just seized?
Posted by quiltdyer on
  • quiltdyer
    quiltdyer Dec 21, 2012
    Thank you so much for the suggested solution from dlloyd44 for the solution to my problem! It works!
Debbi's Sewing Machine Repair
  • Elna Master
  • 7,365 Answers
Try going to the sites of
sewvacdoctor.com
a1sewingmachines.com
and call them or email about a manual and how to get the cam off
that way the cam doesn't get broken
Posted on Dec 21, 2012
  • quiltdyer
    Thanks for your suggestions. The second link you gave didn't work for me.
3 Related Answers
Anonymous
SOURCE: have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Posted on Apr 09, 2009
Anonymous
  • 155 Answers
SOURCE: I need to thread an
Needle Faces Where?
I Need to Tighten the Tension....
Changing a Needle
Need Help
Basic Questions-
Bobbin Assembly Popped Out!
Do You Think My Machine is Fixable?
How to Change a Broken Needle
Needle Bar Adjustment
Oiling an Elna 3007
Getting the Timing Belt Off?
What Size Needles for My Machine?
How to Oil my Machine?
Where to Oil??
Stitch Length Knob Woes
Can't Seem to Put the Bobbin in Correctly
Timing Belt Tension
Adjustments
Running Very Slow-
Oiling Points on Singer 257
Oiling My Singer Touch & Sew
Singer 457
Featherweight Case Odor
Brother XL2010 Q's
Does My Machine Have More Than One Belt?
Cannot Seem To Adjust the Tension
What to Do About a Gumming Up Needle
How Tighten My Bobbin Tension, Please
Is it Covered Under Warranty?
Proper Threading Instructions?
Just a Foot Pedal?
Simple Threading Instructions for a 1036
Threading a Singer 600
Replacing a Blade on a Johnson Ruffler
Changing the Needle
Lubricating a Singer 1036
Thread Balling Underneath
Warranty Info
Machine Covered in Hardened Oil
Spindle Stuck?
Do Motors Die?
Singer 457
Brother Sewing Machine
Servicing My Machine-
Belt Replacement
Lubricating My Sewing Machine
check out this thanks.
Posted on Oct 26, 2008
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: What make of walking foot
You need a low shank style walking foot. Even back in the 80's when your SU air electronic was new, the walking foot sold by Elna was an after market one, and not made by Tavaro. Same with the ruffler attachment, it was after market and actually fitted quite a few makes of machine.
I would just ask the dealer/shop if they will refund your money if you find it doesn't work just in case.
There is a low shank one on sewingpartsonline.com
http://www.sewingpartsonline.com/walking-foot-low-shank-p60444.aspx and they list the SU as compatible with it.
Take off the foot holder on your mache, and you need to fit the little open ended arm over the needle bar and the foot bracket onto the foot with your machine's regular thumb screw. The up and down movement of the needle bar operates the walking foot.
Posted on Jun 25, 2011
Hello, Please can you tell me how to lower the dogs teeth on Elna SU airelectronic 68 so as to do free hand embroidery. Thank you julie Roberts
This model does not have a slide or lever to lower the feed dogs. Instead, it has a little metal plate that you clip onto the rotary hook cover to cover the feed dogs. It should be in your accessory kit if it is complete, its about the size of a postage stamp, rectangular with little legs at each corner. Clip it into the four holes on the hook cover and away you go. If you are doing free motion embroidery you'll need the special foot too also shown in the image below.
Nov 13, 2017 | Elna Sewing Machines
I need a manual for an Elna Air Electronic SU that has "cams". I can not find a model number. What is or where is the model number so that I can order a manual.
Somewhere on your machine, perhaps underneath, inside, or on the back, there should be a plate or engraving with the serial number and the model number of your machine.
http://whitesewingcenter.com/elnaidentify.php
Then search the internet inputting:
Manufacturer + Model + the word "Manual"
Sep 26, 2015 | Elna Sewing Machines
Manuel elna su air electronic
I have a manual for the SU Air Electronic if you are still looking? you can email me on tallygirl98 at yahoo dot com and I'll send you a scan
Jun 23, 2014 | Elna 2007 Mechanical Sewing Machine
The cam seems to be locked up and won't release. I have the settings where the manual says to, but the button does not go down to release the cam.
Is this a Supermatic (green), Star SU (white with blue top) or an Air Electronic SU model, I'm guessing that it is one of these Elna models?
If it is one of the two latter models, then you need to set the stitch width to zero, stitch length to zero to disengage the feeler arms that read off the disc. Then press on the cam release knob in the middle of the Elnagraph.
The earlier Supermatics were a bit different and there was a tool you used to remove the cams I think.
You could try to remove to the top cover and then see if you can get some oil in under the Elnagraph, this may help to free up the mechanisim. There is a little finger that goes into the cam from the underside and you don't want to damage this as you remove the cam.
My other suggestion is to join the "Elna Heirlooms" user group on Yahoo.com and see if one of the members there has a suggestion on how to get the cam off. There are some really knowledgeable Elna owners there so one of them may have encountered this problem too.
Dec 20, 2011 | Sewing Machines
What make of walking foot would fit my Elna su air electronic sewing machine, thankyou
Jun 25, 2011 | Elna 2007 Mechanical Sewing Machine
My elna SU air electronic model 68 is not working I need to fix it. How can I find a repair expert.
I have a Elna air electronic No 69 I am having trouble with the tension . How can I fix this.
Jul 13, 2009 | Elna Sewing Machines
How to thread bobbin on Elna SU
Please describe the type of bobbin you have. Is it held inside of a removable metal casing? Or is it a dropin type? Is the sewing machine what is known as a "freearm" which you can put a sleeve or trouserleg over or is it a flatbed type? When I know this I can help you further.(I used to sell sewing machines).
Jun 11, 2009 | Elna Sewing Machines
Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Sep 21, 2008 | Elna 8007
Sewing Machines Logo
248 people viewed this question
Top Elna Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Nick Olsen
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
