Samsung PCH521R 52" Rear Projection Television Logo
Anonymous Posted on Jul 14, 2017
52" rear projection Samsung Tantus Tv Timer Problem
Hi can someone plz help... my parents 52" rear projection Samsung Tantus Tv is quite old and has undergone several surgeries to the circuit board before but she's still kicking great! There is only one problem though... next to the power button on the bottom the timer light is permanetly lite red and the tv doesn't turn on! There is no button on the remote that says timer or anything. So I'm pretty lost on what next to do.
5 Related Answers
Anonymous
  • 150 Answers
  • Posted on Jul 07, 2007
SOURCE: Samsung 54" rear projection PCL5415R Won't Turn On
Although I am not incredibly familiar with your model, There is most likely a small board mounted above the others near the crts, there is a small red connector with a blue wire if you unhook it it will remove power from the convergence IC's and if they are shorted it might come up with conv out, will need a new module.
Anonymous
  • 3130 Answers
  • Posted on Jul 22, 2007
SOURCE: tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Jaime Hernandez
  • 2351 Answers
  • Posted on Mar 10, 2008
SOURCE: Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Anonymous
  • Posted on Apr 25, 2008
SOURCE: Samsung HCN473W 47 in. Rear Projection can't turn on
Turn the tv off by unplugging it from the wall and wait for the timer light to go off (Might take several minutes).
Once its go off turn the TV back on..Good Luck
Anonymous
  • Posted on Sep 30, 2008
SOURCE: Samsung PCL545R Projection TV
Pull out the plug for the TV and leave it out for one hour at least.  Plug it back in and it should be ok.  It will re set itself.
My samsung tantus shows picture but no sound
there is "audio out" jacks on back side of television. connect it to an amplifier or other tv & hear if sound is comming. if sound is comming then audio amplifier is defective in your tv. if sound is not comming then audio processor may be defective.
2helpful
Samsung tantus blinking red light
you need to general service the whole unit. this will include re-soldering and changing some defective components from the board, which has been damaged through using from past years. my advice is to have a quotation from service tech and then think about repairing it..if it is better to buy a new one..
Samsung Tantus problem
your main power supply is gone out
Convergence is completely messed up and Audio drops
can someone tell me how to fix the convergence the red and the blue are messed up and the picture perfect doesnt work.
3answers
Tv comes on and flick off in one minute
need to know the make and model number of the TV in order to help you.
Good Luck.
Samsung 52" tantus pch521r no picture
1) Loss of color = bad solder connects on signal board
2) Loss of pix = probable CRT coolant leak onto signal board
Have a technician check it out.....can be expensive......T.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
