SOURCE: 2001 Ford Windstar Van- transmission
i have a 1996 wind star van the over drive light is flashing and it downshifts sometime it seems like it is in over drive when you take off. is there a censor on the transmission that needs replaced
SOURCE: transmission problems (gear linkage)
The gear linkages are not correctly aligned.
Is the gearbox mounting in exactly the same place as when you removed it?
Even a 1/4 inch will offset the gears.
hope this helps
SOURCE: transmission shifts very hard from 1st to 2nd
may need to have the kickdown band adjusted. it is applied when the trans goes into second gear and in reverse.
SOURCE: Problem with 95 ford f150 v6automatic transmission -hard shifting
A sticking 1/2 shift accumulator or broken spring in the 1/2 shift accumulator.
SOURCE: manual transmission takes effort to put in gear.
Have the clutch looked at. If the clutch is not releasing fully it makes shifting difficult. Have the trans fluid changed too, it isn't expensive and probably is listed under your maintanance in the owners manual
