Question about Archos Gmini XS202 MP3 Player
PC does not see my gmini xs202
Gmini won't boot up properly but gives the message "Read access error! Can't read from hard disk." Unfortunately connecting it to the PC doesn't help because the PC doesn't see it. Has it died?
Posted by Bernard O'Neill on
2 Related Answers
Inky
Inky Fingers
  • 705 Answers
SOURCE: DEVICE HAS'' READ ACCESS ERROR-CANNOT READ FROM HARD DISK''
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. If not you could try formatting it using a DOS prompt.
Posted on Jul 26, 2007
Anonymous
SOURCE: Gmini hard disk reading problems
My Gmini XS202s did this twice both time cause the battery went flat while moving files across (I should always charge device while connecting to PC)
First time I reformatted device as FAT32 using fdisk (Windows formatting tool should do same)
Then downloaded latest AOS and copied to root directory. [get AOS from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en]
second time I ran mkdosfs /media/disk (disk was mount point for gmini). This seemed to fix the device and I lost about 20 files. but better than reformat.
Posted on Apr 29, 2009
Hitting F8 key repeatedly will not access Safe Mode option for my HP D530
If you getting this error then you won't be able to open computer in safe mood, Because this error message indicate that there is no proper bootable media selected or there is no OS in your Hard drive.
First thing you can do is go to BIOS and check what is your First boot device selected, if it is other then Hard drive then change it Hard drive and save setting and come out of it.
If there is any media, like Pen drive or any CD then remove it and start your computer.
If still you have same problem then I am afraid that your OS is Corrupted.
Aug 20, 2012 | HP Compaq d530 CMT Intel Desktop PC -...
On start up, netbook gives "Disk Read Error. Press
1. See If there is something attached to the computer (printer, usbo devices, phones etc.) . If there is disconnect it
1. Try checking the BIOS make sure the first boot device is the hard drive save the changes and restart the computer
2. If that fails. Try restoring the BIOS to its factory defaults
4. If you can't still boot up. try do a Operating System Reinstall
5. If everything else fails Replace the Hard drive
Thank you for Choosing
Jul 03, 2011 | HP Mini 1000 Netbook
Hello. Completely out of the blue, when I turned my laptop on it immediately went to a black screen that said "A disk read error occurred press Ctrl+Alt+Del to restart." But when I do it takes me...
When your system boots it looks for a startup file which is located on your hard drive to load your operating system. If your system doesn't find your hard drive it would post a disk read error message.
To be sure your HDD is detected by your system, you can go to your BIOS setting by pressing DEL or F1 or F2 or F12 it depends on your BIOS maker then try to see on your BIOS setting configuration if your HDD drive is detected or not.
Sometimes and always happens that we forget a media disc on our optical drive and since the default first boot device is the optical drive the system looks for a startup file on it and post a disk read error. So check if you leave any disc on your optical drive and remove it.
It is very safe to configure your BIOS setting to set the HDD as the first boot device in case we leave something on our optical drive most of the time.
Hope this helps.
May 27, 2011 | Computers & Internet
Turn on hangs on opening logo screen..center button="Read access error! Can't read from hard disk."
Possible causes and solutions
1 The hard drive within your player has failed, not uncommon and a real pain to fix for all but the real hands on techies. requires replacement hard disk likely same size required.
(unfortunately most likely problem) it will probably be accompanied by an unusual clicking noise coming from the player when held to your ear.
2 The hard drive within your player has become corrupt or something similar and requires formatting. Simple for any IT person to do. I'm no expert on this model and am too lazy to check but even holding down the reset button for 30 seconds or so may fix it.
Good luck hope i helped.
Jul 24, 2009 | Archos Gmini XS202 MP3 Player
Dec 17, 2008 | Archos Gmini XS202 MP3 Player
Gmini 402 camcorder freeze/format
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
May 22, 2007 | Archos Gmini 402 Digital Media Player
May 22, 2007 | Archos Gmini XS 100 MP3 Player
Klackitey Klack
If the drive is ticking, it suggests the actual HDD is dying. You can try the following to see if you can fix any disc errors through your PC, however if your PC does not recognise a drive has been attached you may be unable to do anything other than have it repaired elsewhere. If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
Apr 04, 2007 | Archos Gmini XS 100 MP3 Player
Archos Gmini XS202 MP3 Player Logo
59 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
