I have a Siemens Gigaset AL140 phone. It is working fine but I cannot see the caller number while receiving a call. I checked with operator and this is activated in the number. I could not find this in manual as well. Please help
The display should indicate what's going on with CLIP, and why it's not showing up.
You should either see an icon of a BELL, "WITHHELD" or "UNAVAILABLE".
BELL = you haven't requested CLI from your carrier
WITHHELD = if caller has withheld CLI from carrier
UNAVAILABLE = CLI is not requested.
Do you see one of these three on the display when you receive a call?
Other than one of those reasons, I'm not sure what your issue might be.
SOURCE: need a manual for siemens gigaset as185 or as185
Well you can please follow the below link to get your manul -
http://gigaset.com/medias/sys_master/A31008-M2026-L101-1-7643_en_GBR.pdf
Good Luck!!
SOURCE: SIEMENS GIGASET A160 TWIN CORDLESS PHONE
It's not an easy website to navigate, but if you look hard the all the information is available.
Is this the page you were looking for Graham?
Regards,
Spare head 2.
SOURCE: Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
SOURCE: Gigaset AL140/AL145. base phone 1 working
Put the other other hand sets on the base phone charger for 10 minutes and pin will be 0000...
SOURCE: Iwould like a user guide in english for a gigaset
Gigaset is Siemens company. They provide manuals for download at http://gigaset.com
Choose your phone model from the product selection dropdown on the right.
