Cell Phones Logo
Posted on Dec 20, 2012
On my pendo pad THE process android.process.acore has stopped working
Kevin Heaton
Level 1:
Habit-Forming:
New Friend:
  • Contributor 22 Answers
  • Posted on Sep 25, 2013
Kevin Heaton
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
22
Questions
Helped
7243
Points
80
Hi you will probaslly have to flash the pendo pad, its not too hard to do here are my instructions, - unfortunatly a pendo pad does not have a recovery menu to access on device boot
note - this solution also unlock the pendo pad and restores it to factory settings even if it wont boot the android os
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back to the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
3 Related Answers
anilbr
Balakrishnan Computers (A Computer Repair Shop)
  • 468 Answers
  • Posted on Oct 26, 2010
SOURCE: how do i get rid of error message "the application
It happens when the process is manfuctioned or corrupted. I advise to do a factory reset. To do so, turn off the phone, holdon the home button and press the power button. It will go to recovery console, now select "Wipe to factory setting", once finished, turn off the phone and restart. It should take care of the issue.
Thanks and regards,
Anil.B.R
Anonymous
  • 181 Answers
  • Posted on Feb 03, 2011
SOURCE: i get a force close message on my phone. what do i
This basically means the OS is having severe problems. You need to try a master reset first. If this does not work and there is no software update available from the HTC website you need a replacement handset.
Anonymous
  • 45 Answers
  • Posted on Mar 25, 2011
SOURCE: My touch screen will not
brother open your phone if you can and reinstall the parts of re-heat it there are parts of it that are lost contact to the other parts or you can just go to a nearest service center in your area
How do i fixandroid.process.acore
http://androidforums.com/threads/how-to-solve-error-unfortunately-the-process-android-process-acore-has-stopped.854534/
Scroll to the bottom and try the solutions in the green box.
The solution on the top is drastic and I wouldn't advise it unless all else fails.
1helpful
I keep getting a report box android process acore has stopped
Look at the green box at the bottom first and try that.
The factory data wipe/reset on the top should only be tried of all else fails.
1helpful
2answers
My son's pendo pad 7 won't turn on at all. I've currently got it on the charger but unsure if it's even charging :/ how can I tell if it's actually charging? Please help.
Unfortunately if there are no lights on the charger itself there is no way to tell. If you are just getting a blank screen and no indication that the LEDs behind the screen are lighting up or anything is happening at all, you may have a mechanical hardware failure. This could have been caused from water, a drop or some other hazard like extreme heat.
Your best bet is to find a local PC repair shop that services tablets or contact the manufacture and arrange a service ticket.
1helpful
3answers
G'day. I can not access my pendo pad I have forgotten my password. I am locked out of it. How can I get into my pendo pad.
Craig, jump onto YouTube and search on "Pendo Pad Reset" for ideas. Lot's of good stuff out there and standard reset steps for Android devices are covered.
1helpful
TABLET / LAUNCHER ERROR ANDROID 4.2.1
My tablet recently did the same thing. I tried everything but I eventually had to do a factory reset. Good Luck
Screen says,the process android. process.acore has stopped working
sounds like a software issue you will need to completly re-install the software back to original factory settings if this continues after you have tried this will be an addition fault on the logic board
1helpful
The process android.acore has stopped unexpectedly.please try again
The only solution I have ever gotten to work when it comes to "acore" stopping is to do a factory reset on the device.
2answers
The process android.process.acore has stopped
please try to reset its because of the software corruption it usually happens in Htc models...
1.Phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
2. Wait for the phone to finish the reset process and then press MENU.
if it does not solve upgrade to latest firmware
Update to latest version
http://www.htc.com/www/support.aspx
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 • HTC G1
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
