SOURCE: need to set a pitney bowes 9820 to print a fax confirmation
Function
74
set
12
set
set
stop.
SOURCE: Pitney Bowes 1530 Fax Machine
On top of the operating panel is a small removeable tab with a bump on top. (not the Blue ones) Pull it out of the machine This is the battery holder.
The battery is a CR 2032. Most electronic stores sell them.
SOURCE: New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
SOURCE: Pitney bowes fax machine model 1630 has 76 error
The heater lamp in the fuser is broken. Call 1 800 243 5556 for service.
SOURCE: 9720 Pitney Bowes Fax - access code has mysteriously been placed
Function 9, access code is 9720, press yes, press no until you get to set access code? press yes, delete code, press yes, press stop. I don't think this manual in online any more, but you can go to www.oceusa.com, go to drivers and support, and look for 9820 or 9800 series. The programming instructions are the same as this model
